  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Did you loose your MR2?
yeah lost it into a tree out at yatla :rofl: everyone seems to think its the same as a normal rear wheel drive. i have had front motor rear wheels out sideways before, the mr2 :| once u back off and rear end drifts out, thats it cause where ever the rear end goes u go :| even in the drift bible they say its one of the hardest to drift :|
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
