  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. seriously... imagine your gearbox without oil.
it would be farked the moment your hit 1st.
well i got a story on that
my aunt has a cq60 merc
and she took it to be serviced
and they never put gearbox oil back in
she then drove half way to dbn (+-350kms)
and then it seized
she then said "i tought i could hear something whinning and getting louder"
yes i will take 10litres pls
get Rozz to try it as well.
the specs for turbolite are:
TYPE OF USE
Specially designed for high performance engines
All gasoline or Diesel engines, Turbo or naturally aspirated, multivalves, with carburettor or with injection, with or without catalytic converter.
Suitable for all types of fuel : standard, unleaded, Diesel fuel, LPG.
All driving conditions : City, Road, Highway.
PERFORMANCE
STANDARDS ACEA A3 / B3
APPROVALS API SL / CF
VW 505 00 / VW 500 00 quality
Mercedes Benz page 229.1
* The new standard API SL is more stringent than API SJ in terms of ageing resistance (average drain interval increased), requires anti-oxydation properties that maintain a constant viscosity avoiding sluge and deposits in the crankcase, anti-wear properties and dispersent power
The synthetic base stock provides high lubricating power and protects perfectly the engine while in intensive use on road, highway or in town.
The high performing anti-wear additivation results in reduction of engine internal frictions and increases life duration by wear reduction.
SAE 10W-40 viscosity grade is fully adapted to recent gasoline and Diesel engines and ensures easier starts.
Very efficient anti-deposit and anti-black sludge power which keeps the engine clean.
Anti-oxidation, Anti-corrosion, Anti-foam properties.
and then it seized
idiots.
that's why i like to do the servicing myself. at least i know WHAT kinda oil is going in and i can take my own sweet time.
i usually leave the engine oil to drain for 2 hours :(
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
