  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
last time, Nick.
engine oil - go motul
diff and gearbox oil - go redline
brake fluid - Castrol GP600
Coolant - anything concentrated. I went Repco
spark plugs - NGK copper/plat/irid.
Oil Filter - Ryco
Petrol Filter - PLEASE GET NISSAN ORIGINAL
mmm yeh well it depends on how much time u have glenn.... if u dont have time then i guess they'd be no point in doing much
get everything done once and for all. dun stop halfway.
watch Neil and learn from him. i will be there to guide.
krazy with a K
anyday this week, i am free most of the time,
and maybe heading to noosa tomorrow for monday and tuesday maybe wednesday
protect your car.
Noosa = seawater = salt in the air = air into your car = RUST.
nick, get the stuffs first.
both of you still need to get the DIY Brake Flushing kit. Its $7 from Supercheap. It a long transparent tube with a black rubber head stopper at one end.
also, you need to get 2 suction pumps (like the ones you see in my gearbox oil change thread)
AND PLEASE BUY AT LEAST 2 CANS DEGREASER ... EACH!!
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
