  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
OMG! you would think i would learn the first time ..
Today i was strolling home in the skyline, not wearing a seatbelt as i wastoo busy trying to hold my supa-size coke, when around the croner come one of the heat cars.I freak and reach for my seatbelt .. but i knew it was too late.. so i just looked at him and took a sip from my supa size coke.
VERY LUCKY .. he just kept driving by.
Then, tonight coming up to yatla they had a camera hidden on the side of the road, i was doin 130 - 140 .. when a car 2 cars infront gets clocked, and i was VERY LUCKY i saw the flash
Finally on the way home, i decided to take the backstreets and i come up to this rondabout and i couldnt help it, so i drifted around it twice, tyres screeching blow off valve Pshing .. and smoke hazing from the tyres..
I pull out and around the corner about to plant my foor away from the scene of the crime, and what do i see.. 2 police cars on the side of the road.
LUCKY for me both of the coopers where outta the car and appeard to have priorities
You do realise that not only would have got booked without a seat belt on (which is ****en stupid in itself) that you also would have been booked for drinking whilst driving. A new law was passed a while ago saying that you aren't allowed to drink or eat food whilst driving...
Do you want us to give you a badge now? Cause your soo cool?
Guest
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
