  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well I had an interesting 31sec run, dumped it in first wheel spun all the way, just got grip went for second, nope, ok try second again, pumping clutch madly, nope ok so I have lost by now, lets try third, nope fourth nope second nope third nope fourth nope :rofl:
Happily coasted though and let her stop and cool down for a bit and all seemed fine so I went for a couple more runs :D
BUT God damnit coming back onto the highway afetr our little get together at yatala I got flashed getting onto it, was well over 120 so not happy jan :)
sux about that fine ska, i didnt see the cop when i floored it onto the highway ??? but i wasnt speeding either
Yeah but you all went south I went north, sould have remembered they hide one in there, just tired and wanted to get home :)
Guest
