  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ben - wassup buddy.... wat's the latest on your new job?
Nick - i have got 2 exams on monday and Neil's got a paper to sit for too. i reckon thursday or friday. dun push it.
mindflux - wat's wrong with your gearbox?
Neil - lemme me noe how it goes with the intercooler. if you need tools, just give me a call.
Sam - where were you last nite? it was the daylight crew vs the graveyard shift crew (just me and ben !!)
Matty - *MUACKS*
Guest
