Hey sau,
purchased a HKS intercooler not long ago and I'm looking at completing my catback exhaust system. I have a query and was wondering if this is a direct bolt on product and can it be used on the stock turbo application. I know it states it can be but just need to be 100% sure before i purchase this. Will there be much performance increase and will it be noticeable. Here is the link... http://www.nengun.com/hks/stainless-front-pipe
My second question is if this dump pipe can be put on my stockish application im running so far. Will there be any performance increase if this item can be used. No turbo modifications of any sort so far here is the link for it... http://www.nengun.com/hks/extension-kit
Best regards chris
Both will fit your stock turbo and current cat back exhaust system.
Dump Should give you a more free flowing exhaust
thankyou for your help will be purchasing both these products to put on in the near future
best regards chris
Consider this also:
http://www.justjap.com/store/product.php?p...cat=&page=1
Much cheaper and will work just as good for a stock turbo. There will come a time that the stock turbo will bore you and the chances are you will want something like a garrett, which your expensive HKS dumps wouldnt work with.
With the cheaper pipe your losses are much less in that case.
Consider this also:
must bolton replacement turbos for rb25 use the std rear turbo housing design, so the hks dump will work just fine
Think i might go with HKS but thankyou for the information iam registered with just jap allready. Will both these products be able to be bolted on? Or will i be able to put one on and not the other
best regards chris
