hi guys i'm new here. I recently purchased a r33 GTST pretty stockish has a exhaust and front mount cooler and 10psi boost.
I red lined the car today for about a second and something made a slight metal 'ting' sound and now the car drives funny.
The car is completely normal to drive under no boost, however, when you step on in, it only boosts to about 4psi and the induction sound sounds different to what it did before.
also, I didn't have a BOV on my car so it used to flutter before, now, when I release the accelerator, it just makes a funny 'shhhh' sound from somewhere.
I checked all the pipes and simple things like that, but I couldn't find anything?
Could anyone with knowledge about these cars shed some light as to what it might be?
I've tried searching and have found nothing unfortunately.
thanks and peace!
  • Replies 63
im not 100% familiar with RB motors since i am very new to skylines and very rarely work on them but im a mechanic and it sounds like maybe you could have bent one of the butterflys in the intake.
seems to add up to me because the lack of blow off valve would have left excess pressure in the intake when you backed off and a bent butterfly would cause lower vaccum pressure which would then in turn affect the wastegate actuators.
<A name=OLE_LINK73>You can comprar moncler outlet in every tienda moncler and easily find every type of it. The main feature of these leather moncler usa is fabric. Nylon is being used to design these vests which restrict the cool air to come inside your moncler sale body. You won't feel any cold while you are wearing a piece of moncler 2010 on your body. What's most, it is comfortable and light to wear. As we all known, the traditional normal winter Moncler clothing has to been weight and massiness to keep us warmming during cold winters. You have to discard your colorful nice moncler.com and put on thick fat moncler down jackets in order to keep warm. But now, things can be change because of this lightness moncler jacket sale. Its excellent thermal effect, its beautiful design and its comfortable wearing black moncler jacket will give you a warm and pleasant winter. Chaquetas moncler men jacket in striking colors can make your personality superb and this is the best time, when you can purchase your favorite colored moncler jackets. The cheap moncler Kids jackets come at colors such as pink white, blue and black and are cut in moncler sweaters shop way that they give a chic, definite appearance of your figure. You can match moncler jacket women with any of your Moncler jackets for women because its combination enhances your personal. Come with moncler womens jacket, go to the different winter this year. http://www.mcjacketsale.com/
:blink:
His is a GTST, not a GTR, therefore it has one butterly, not 6.
Anyway there really could be a number of possibilities and without knowing the full story every one is simply going to be guessing. Most likely sounds like a small boost leak though.
Edited by PM-R33
as i said im not extremely familiar with the engines, i own a gtr and was going off that.
wouldnt it be good to go off a mechanics guess??? even though it is over the internet
check my option out first, its the easiest, and costs nothing.
Thanks for the opinions. I don't think it would be a boost leak, if it was wouldn't I get boost spicking? Also, I would still get some sort of flutter or bov sound even if it was a boost leak yeah? But thanks again guys, will check the butterfly tomorrow. But if it was the butterfly wouldn't the car run funny the whole way through not just on boost? Thanks again
nah it would still run normal because the computer would compensate.
when i say bent i dont mean bent in half, i mean a slight bow in the butterfly.
I hear what your saying Ben, but that doesnt explain the loud ting at WOT.
Something has broken or split at full power , trozzles idea sounded more plausible..
Or as i said my turbo bolts wound themselves loose and i was having these same symptons.
If your lucky its just a leak somewhere..Keep looking
Edited by Arthur T3
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
