A friend of mine just gave me two peices of gear for my R33 (well my girlfriends R33)
A Blitz SBC i-color and
a Greddy eManage ultimate
Given that i am a skyline noob, is the R33 computer tunable or is it best to go with a piggy back setup?
What benefit is the SBC i-color going to provide other that boost control?
Any feedback would be appreciated............
https://www.sau.com.au/forums/topic/343243-performance-options/
Thanks guys,
more questions,
Can you re map a R33 computer or do you need to run a piggy back setup?
What sort of power would you expect to see out of an RB25 with tuning mods?
What sort of boost will it handle with no internal mods?
Assuming it runs standard turbo with big front mount cooler, pipe work, exhaust you know just the usual stuff.
Any ideas appreciated........
a little over 200rwkw with tuning
no you cant remap the RB25 ecu but there are options like the eManage you have
you will want a front mount intercooler, oil cooler if you plan to track it will help keep engine in good nick
Yeah cheers MADAZ,
Already had a front mount on it, you wouldn't happen to know a good place to install the eManage, best to get it done profesionally done i am assuming.
This may be a bit of a silly question but i am getting over 350rwkw out of my XR6T, i understand they are a bigger capacity motor but it is only with bolt on stuff, fuel pump, injectors, big cooler, flash tuner.
I guess the question is this, how hard would it be to acheive 300rwkw out or the little RB25??
Yeah cheers MADAZ,
Not very hard. Strap on a 3076 and profit
Can you introduce me to your friend, I want a friend that will give me that sort of stuff!!!!
If it's the dual solenoid boost controller (type R) you have yourself one of the best boost controllers on the market.
And the Emanage Ultimate is the best piggy back on the market.
RB25s can be modified to be tune-able but an Emanage or Power FC is what most consider the better option due to the ease of tuning.
If you fit the boost controller you'll be able to safely run 10-11 PSI MAX on a standard turbo. The emanage will be able to compensate for the R&R (rich and retard) that happens with that sort of boost. It's probably not worth putting them on unless you have a free flowing exhaust on there already.
ecu options
rb25 ecu, external emulator needed. only person i know that does em is dr. drift in vic.
rb20 ecu with nisstune, common chip mod, loose vct
z32 ecu with nisstune, same as rb20 but with vct and direct support with z32 air flow meter which you will need for 300rwkw anyways (or q45 afm for 300+)
power fc, most common but no safe map... if it starts knocking and you dont realize or dont ahve ahand control unit it could end in disaster
microtech, haltech, motec whatever tech, stand alone ecu's most have a map sensor therefore no need for afm.
then you have your piggy backs like emanage or other jap stuff which are ok but the time and money youll spend getting it right might as well go nisstune/power fc
out of a standard turbo setup with exaust and cooler on 12psi you will get close to 200rwkw, a bit over with a re-tune
for 300rwkw youd be looking at fuel pump, air flow meter, injectors, turbo and some sort of ecu. I would also reccomend a metal head gasket. there is plenty of options on which turbo to go for... depends on what you want to use it for and how responsive you want it to be.
Edited by SkyHi_33
Adrian is the only one making that sort of power on a standard bottom end .... and how long till it goes boom? (mind you his only survives cos 1. he is a great tuner and 2. he can touch-up tune it whenever it suits him - unlike the rest of us). The engines are just not designed to hold that sort of power .... the RB26 however is a different kettle of fish :thumbsup:
Plus to make that sort of power on an RB25 you have a lag monster on your hands .... unlike an XR6 with 350rwkw that pushes significantly more exhaust gas.
Adrian isn't the only one i know off....Lee makes something like 356rwkw out of an unopened 25 as well...have seen that car around a lot :rolleyes:
but i do see your point that a stock RB25 without forgies or head work making 300+ rwkw is a risk that it could let go any minute......to be able to push that much power make sure the ground work is there to support it :blink:
There will always be the knockers out there which is fine. Couple of things i have noted running E85 (please note this is my experience).
1. My car has been on E85 for a couple of years seeing plenty of road and dyno use and doesnt use a drop of oil.
2. Its 350rwkw or thereabouts
3. Its unopened
4. Max boost is all in by 3800rpm (23psi)
5. Its scary on street tyres
6. It puts a smile on my face every time i drive it.
7. Semi slicks still struggle in 3rd and 4th gears
8. It looks stock under the bonnet with stock mani's
9. Fuel lines are standard and are showing no sign of failure (Changed a couple filters first up tho)
10.Car has got next to no blow by(have never had to empty my catch can)
I could keep going but wont.
When my engine starts to get tired i can guarantee a Forged engine will not be on the shopping list.
Yes thats right a lowish k stocker for $1800 will be purchased.
Seems like i will need to spend bucket loads to a car that is still not as quick as my XR6T. Not really a fair comparison i guess given differences is engine capacity and turbo size.
For my 2cents it seems a bit redundant, what would be the benefit of me spending more on the R33 to get 300kw then i have to get 350kw out of my XR?????
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
