Seems like i will need to spend bucket loads to a car that is still not as quick as my XR6T. Not really a fair comparison i guess given differences is engine capacity and turbo size.
For my 2cents it seems a bit redundant, what would be the benefit of me spending more on the R33 to get 300kw then i have to get 350kw out of my XR?????
Its like comparing apples to oranges mate. XR6T is in a whole different class. 350rwkw out of a XR6T would still not be as fast as a 250rwkw GTST around mallala. If your going for outright speed and power then modding the XR6T off its head is where i would be going but if it is going quick around mallala then GTST is where my $$ would be going.
You have to decide what you want out of both of your cars mate. In the end you would prob make 350rwkw out of your XR6T and drive happily not really worrying about coping a defect as well.
So when has either an XR6T or R33GTS-t been fast around Mallala?......
I must have blinked and missed it :down:
Having said that a couple of years back in the Manufacturers championship David Ryan had a near stock (as they all are in that class) XR6T that we supplied a tune for, ran some - very - nice numbers at the Creek etc won a lot of races and I believe the championship. Should have been in the 1:17 slot or on that pace at Mallala so dont discount anything if it has the right setup and driver ;)
I thought malala was just some donkey track in a paddock in regional sa lol last time i went ardound it on my R1 i thought it was a motocross track lol just jokes
as mentioned, both cars are very different in dirveability, the way they put the power down and generally well... everything.
really depends on what you want it for and how you set it up. the last part is key, set up.
if you spend money on a bunch of parts to make a magical figure and only focus on that, then yeh it probably will be "fast" but doesnt mean it will be reliable, responsive, offer a great deal of feedback or be very driveable overall.
hey put it this way, know of a certain 380awkw gtr, the guys spent all his money on the engine, chucked in some second hand jap coilovers and called it a day. My gtst with just under 200rwkw and a massive flat spot in the power curve getting there shat all over it through the twisties.
in a straight line theres no comparison... 380awkw will eat almost anything else on the road.
my point being, two cars set up for two different things.
Could be a couple of reasons.
1. He wasn't trying
2. Driver ability
3. He wasn't trying and you were
Either way i find it hard to believe that a Gtst at 200rwkw (even with all the fruit suspension/tyre wise)would even come close to a 380rwkw at all 4 GTR (even with stock suspension) if both drivers are on par for ability and experience in the twisties up in our awsome hills.
I'm no expert but i can tell how much quicker my Gtst is at 350rwkw than it was at 200rwkw through the twisty stuff, then throw the GTR into the mix and theres alot more potential for speed.
Yes driver ability does come in to play, considerably too at times, but having a laggy setup versus a stockish responsive setup also has its perks. Suspension setup is also a crucial element when taking cornering ability in to play. Gtr being awd or not, with just a set of coilovers in it does not mean it will handle better than a standard factory set up. It comes down to alignment, both static and dynamic, stiffness, rebound, and overall coilover setup matched to the road conditions, tyres and power output of the engine, and more importantly the way the power is delivered... and a lot more of where that comes from.
Im not saying im keiichi tsuchiya by any means, far from it (i tend to stack in to things often) but I do spend my time figuring out how to make the most out of my suspension and i do occasionally really push my car when i can, am alone and is safe to.
The above post had nothing to do with me measuring my dick against everyone else etc. i do apologize if it comes across that way, there is too many variables as to why it happened. I was merely trying to put a point out there about different car setups delivering different outcomes. :D
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
