Hey all,
Does my series 1 r33 have a cabin air filter? if so where do i find this and how do I replace it??
Cheers
yes, all cars have cabin filter, in the 32 and 34 its in the aircon unit behind glove box, call nissan, changing it is a simple case of unclick panel remove filter insert new filter replace panel
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5537628
i am also rather interested in knowing if there is a removable filter in the R33s.
in the past when i have taken out glove box and surround, i have never found what would appear to be a removable filter of sorts... maybe i'm just not looking in the right places.
surely someone would know, or someone with with their dash removed has seen it.
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5538972
I thought I had seen a thread somewhere on this before for an R33 but I think it was the one for the Stagea I was thinking of which had photos.. thread here.
The below was taken form this thread...
1. remove glove box. There are 2 sliding clips at the bottom of the box (stick head into the foot well to see them), you slide them and pull them out, that will let you take the glove box out. There is a retracting cable that is attached to the right hand side of the glove box, that needs to be slid off to let you remove the whole box.
2. remove all the screws behind the glove box, including the clip that the box grabs to in order to stay shut. Can't remember how many, probably 4 or so. This lets you take the whole panel off and reveals the aircon blower and filters.
3. locate the rectangle white plastic thing. there is a metal clip on the bottom, take that off. then slide the whole plastic thing up and that allows you to take if off.
4. now the white plastic rectangle thing is off, the filters are revealed.
Might have to give this a look myself to see what condition they're in.. maybe clean or replace them.
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5557791
  • 4 years later...
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
