hey guys,
i have decided to cancel my RB26 project and go another way
the turbo has done a dyno session with the old set up but the Tial exhaust
housing is brand new.
Garrett GT42 with brand new Tial housing 1.00 $2700
Brand new hypertune plenum with hypertune throttle body $2600
brand new ceramic coated 6Boost manifold to suit turbosmart 60mm gate and tial housing $1400
call chris 0451372955. live in adelaide but can post austalia wide
Edited by CkRacingDevelopments
https://www.sau.com.au/forums/topic/343277-high-performance-parts/
[email protected] email me if you have the manifold
hey guys,
!!!!!!!!!!!!!!!!!!!!!!NEW PRICES!!!!!!!!!!!!!!!!!!
HYPERTUNE PLENUM + THROTTLE BODY $2300
TURBO WITH BRAND NEW TIAL HOUSING $2200
6BOOST MANIFOLD $1300
FREE DELIVERY WITH IN AUSTRALIA FOR ALL THE ABOVE
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
