Selling this genuine Nissan V35 Coupe front lip, comes unpainted, white gel coated ready to be painted to suit your car. To fit all 2003-2006 CPV35 2-door Coupe with factory front bumpers. It will not fit NISMO front bumpers.
Comes with all mounting hardware and installation manual (in Japanese) with lots of pictures any 7 yo kid who builds Tamiya can follow it, so should yourself or your spray painter/body panel tradies be able to follow it through as well...
Bought this from JapanParts was going to but didn't got time to put it on my car. Now that I've sold my car I have no need to keep this.
My loss is your gain. I had this shipped from Japan costed me over $500 including shipping! Here is a link for more info.
Looking for just $350... they are not cheap fibreglass, they're genuine OEM Nissan part!
I can organise shipping interstate if required as I still keep the box that Japanparts used to ship it to me.
  • 1 month later...
Still for sale... asking price lowered to $300
Hi Rianto,
Can you ship to Perth? If so, can you please pm me the total price?
One of my friend (Not on SAU) is looking for one and I am sure he will be interested. I will let him know tonight via Facebook about this.
Thanks Rianto.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
