1996 Nissan R33 RB25DET Manual SERIES II
Accident free, never been defected, neat and smooth.
Approx. 103xxx kms
Engine:
Standard turbo running standard boost
R34 GTR front mount intercooler
CES Racing 3" front/dump pipe (splits flow until underneath the car)
4" Magic Cat
4" Catback to 5" tipped cannon (I believe HKS Super Dragger - perfect note)
Wheels/Brakes/Suspension:
Tein HA all round
Whiteline camber bushes up front (rears included but not installed)
18x8.5+30 18x9.5+35 Work Meister S1 rims - excellent condition
Brand new 235/40's all-round (I think they're Kumho Ecsta - it's late)
Exterior:
Standard series II
Clear side indicators
Interior:
Brant Remote Central Locking/Alarm with pin pad and new remotes (driver motor for central locking needs replacement)
Alpine Head Unit
Alpine 6.5" Component Speakers in front
Alpine 350W RMS Amp
12" Alpine Subwoofer in enclosure
Other Parts Available but not fitted:
Sard Racing BOV
Stock Suspension
Stock wheels with roadworthy tyres
Thule roofracks!!!!
Left hand foglight assembly (an Einstein on ebay sent me the wrong side)
PRICE: $9500
Good clean car. I've owned this car for 2.5 years now and since moving into the city, my fiance and I only ever use 1 car, hers. So this just isn't getting used often enough to justify the rego payments. I bought it with ~85K kms on it and it's now ~103K kms. I had the timing belt, all fluids, filters, rocker cover gasket, and exhaust gasket replaced this time last year but otherwise self-service it every 5000kms. It has one of the best exhaust notes I've ever heard, security is top-notch, handles great and looks tough. On the downside, it has begun developing a misfire in the top end which I know Splitfires will fix (confirmed by mechanic). I never give it heaps so it hasn't bothered me (<5k rpm). Driver's side lumbar support is torn as they all are. Similarly, the driver's side power window switch is cracked which appears to be a standard thing. Rear-left shock knocks in the top spherical joint on certain lightly bumpy roads. Otherwise, it's in great shape with no accident history and never been defected.
8 months rego left. Car is located in Melbourne.
For any questions or enquiries feel free to contact me on 0417 592173. Happy to provide additional pictures upon request.
Cheers
Mike
Edited by pkmike
https://www.sau.com.au/forums/topic/343299-96-skyline-r33-gts-t-series-2-9500/
Tyres are brand new Nankang NS-II's.
More pics;
I took it out tonight and remembered it has a wacko-tacho. Apprently they can be repaired but replacement would be my suggestion. Unfortunately interior trim clips and I dont get along so I will leave this to someone else...
Prefer a quick sale so am open to reasonable offers.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
