FS: 1994 R33 Skyline GTS-T manual 4-door Sedan. Mild modifications listed below
INTERIOR
GTR front seats
Nismo 300km/hr speedometer
Apexi EL boost gauge pillar mounted
Trust Gearknob
Turbo Timer
Tinted windows
Genuine floor mat set
Kenwood flip-face CD player
Polk splits front
Alpine co-axial rear
EXTERIOR
Borbet german made 17x8 wheels with near new Dunlop Le-Mans 235x45x17 tyres
KYB lowered coilover suspension
Calsonic front strut brace
ENGINE
Apexi Power FC full engine management
Apexi Power Intake pod filter in custom insulated alloy cold air box
Turbosmart gated manual boost controller
Custom Mick’s Metalcraft front mount intercooler bar and plate with cast end tanks and mandrel bent aluminium piping. Core dimensions 600x300x75
Micks Metalcraft oil catch can
NGK Iridium plugs
HKS stainless dump pipe with split wastegate pipe into full 3” exhaust, hi-flow cat and Trust cat back system
GFB Hybrid BOV
Exedy Heavy duty single plate clutch with 2400lb pressure plate
All engine mods carried out within last 6 months. Car will be dyno tuned shortly. Usual options such as power windows/mirrors, climate control a/c, ABS and is also fitted with alarm system with automatic power window roll-up and boot release. Has 73,000 kms showing on clock. Have owned car for nearly 3 years averaged only 8,000km a year.
Serviced only with full synthetic oil. 6months rego. Very regretful sale due to another impending addition to the family. Located in SE QLD. Asking $23,000 email [email protected]
https://www.sau.com.au/forums/topic/34330-fs-r33-gts-t-sedan/
Parts I will most likely sell would be
Power FC and HC
Power Intake and CAI
Front mount IC
BOV
nismo speedo
Trust gear knob
oil catch can
exhaust
boost controller
GTR seats
some of these I would have to do a deal with cash + original part eg Power Fc and seats.
As I said before I would prefer to sell car the way it is and will only do this if it does not sell in the next few months.
No worries Adrian, if I decide to do it, I'll let you know first before I post details. Could be a while though as I have to go away for work until the end of june, car will be put in a car yard for that time and if it does not sell I will do it then
Suits me down to the ground... Best of luck with the sale!
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
