FS: 1994 R33 Skyline GTS-T manual 4-door Sedan. Mild modifications listed below
INTERIOR
GTR front seats
Nismo 300km/hr speedometer
Apexi EL boost gauge pillar mounted
Trust Gearknob
Turbo Timer
Tinted windows
Genuine floor mat set
Kenwood flip-face CD player
Polk splits front
Alpine co-axial rear
EXTERIOR
Borbet german made 17x8 wheels with near new Dunlop Le-Mans 235x45x17 tyres
KYB lowered coilover suspension
Calsonic front strut brace
ENGINE
Apexi Power FC full engine management
Apexi Power Intake pod filter in custom insulated alloy cold air box
Turbosmart gated manual boost controller
Custom Mick’s Metalcraft front mount intercooler bar and plate with cast end tanks and mandrel bent aluminium piping. Core dimensions 600x300x75
Micks Metalcraft oil catch can
NGK Iridium plugs
HKS stainless dump pipe with split wastegate pipe into full 3” exhaust, hi-flow cat and Trust cat back system
GFB Hybrid BOV
Exedy Heavy duty single plate clutch with 2400lb pressure plate
All engine mods carried out within last 6 months. Car will be dyno tuned shortly. Usual options such as power windows/mirrors, climate control a/c, ABS and is also fitted with alarm system with automatic power window roll-up and boot release. Has 73,000 kms showing on clock. Have owned car for nearly 3 years averaged only 8,000km a year.
Serviced only with full synthetic oil. 6months rego. Very regretful sale due to another impending addition to the family. Located in SE QLD. Asking $23,000 email [email protected]
https://www.sau.com.au/forums/topic/34330-fs-r33-gts-t-sedan/
Parts I will most likely sell would be
Power FC and HC
Power Intake and CAI
Front mount IC
BOV
nismo speedo
Trust gear knob
oil catch can
exhaust
boost controller
GTR seats
some of these I would have to do a deal with cash + original part eg Power Fc and seats.
As I said before I would prefer to sell car the way it is and will only do this if it does not sell in the next few months.
No worries Adrian, if I decide to do it, I'll let you know first before I post details. Could be a while though as I have to go away for work until the end of june, car will be put in a car yard for that time and if it does not sell I will do it then
Suits me down to the ground... Best of luck with the sale!
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
