this is a r33 bare shell
good to use for
front cut
side panels
rear panel
number job ?? (yes indeed dodgy)
it comes with absolutely nothing!!!
the boot lid is NOT included
it does still have front an rear windscreen an rear left quarter
whatever is in the pics below is what you get price is $300
pickup is in wollongong
call me on 0411241499 u can pick up same day u call if ur keen can pick up almost any time
other parts i have are:
r33 front suspension $75 (all thats in the pics is what u get)
r33 mirrors $35ea
r33 standard sway bar $35
rear lights $40ea - $75 both
r33 condensor $25
r33 rhf guard $50
r33 drivers glass $15
r33 passengers glass $15
r33 overflow $10
r33 carbon canister $10
r33 exhaust aftermarket big cannon - cat back $150
2x r33 stockies $40
r33 dash + dash clips n glovebox etc$40
r33 dash support bar $10
r33 door locks $15 for both
r33 doors both are damaged drivers is beyond repairs passengers fixable check pics $30 for both
r33 trim column surrounds $10
r33 left trim sill panel $5
r33 turbo heat shield $5
r33 series 1 idicator in front bar $15
r33 kickpanels $10 both
r33 series 1 rear bar $50
r33 full working sunroof with all wiring/motor an bolts $35
r33 sunvisors + rear view mirror $15
r33 heater/aircon control $20
r33 heater $20
r33 all seatbelts $25
r33 windscreen wiper stalk $10
r33 wiper arms $10 both
other parts currently selling!!!
all 180sx ac piping an condensor $50
s13 stock auto cat exhaust $20
s13 intake plenum stock $20
s13 NA rocker cover $30
BA falcon master cylinder/ starter motor $20 unknown condition
s14 cut up front bar fits big front mount maroon $50
r32 stockies set of 4 good tyres $150
IF U WANT THE WINDSCREEN OR REAR SCREEN $40 COME POP EM OUT BEFORE THE SHELL GOES!!
CALL ME ON 0411241499
Edited by Ty$
  • 4 weeks later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
