  • Replies 121
I'll put these settings up for your idle etc.
Rev/Idle
Rev limit - 7600rpm
F/C - 1270
F/C - 910
Idle - 870rpm
Idle - 800rpm
With these settings it does'nt hunt at idle and when at normal operating temp it idles sweet as.
Ok here is mine.Fuel table looks shit :Paranoid: and not much timing was put into it :Paranoid:
Looks to be ok mate, overall it seems to be a bit more fuel and a little less timing than the map I currently have, I haven't had a good look at it yet
If I get chance I might default my PFC and write down the default maps and see how differant they are
Once I have my car tuned properly ( I am going to see the guy who is doing the tuning today ) I will post it up for comparison.
Judging by the other thread about the injector compensation, I can either try your fuel and timing map or default it and just use the injection correction function
Just going through everything last night, still on my list is a metal turbo to AFM pipe, and install the Z32 AFM as well
Does yours have a Z32 AFM R31 POWER?
Regards, Chris
Rev/Idle
Rev limit - 7600rpm
F/C - 1270
F/C - 910
Idle - 870rpm
Idle - 800rpm
Dont be weak...should be
Rev/Idle
Rev limit - 10,600rpm
F/C - 1270
F/C - 910
Idle - 870rpm
Idle - 800rpm
:D
Whats your rev limit Roy? my chipped ECU is 8200, and it has seen it quite a bit!
I reckon 7600 is a pretty safe rev limit, I guess as most RB20's make peak power at around 6500 odd, a lowish rev limit will help with reliability!
I wonder how long it would last at 10,000rpm? I am sure the hydraulic lifters would love that sort of treatment!
Chris
Also, just a quick one, does anyone know if the S1 R33 AFM pinouts are the same as R32 GTSt? I am putting on my Z32 AFM as well, but can only find a wiring diagram to suit RB25
Joel used to run a S1 R33 AFM on his carand the AFR's where the same, leading me to believe the wiring diagram for the R33 - Z32 AFM will suit RB20
Any suggestions?
Chris
Hahahahahaha Roy i know I'm a little weak :P i might set it to 8000rpm once it has more boost.
Hey Chris this is how I wired my Z32 AFM in.
Wiring for Z32 AFM into R32 GTS-T
Z32 terminals are lettered A Thru to F, total of six terminals of which 5 are used on the Z32 and 4 on the GTS-t.
Working from A upwards as follows:
A: do not use
B: connect to Black wire on GTS-T MAF loom
C: connect to black/silver
D: connect to white
E: connect to black with white tracer
F: do not use.
Im only running 6050 rev limit at the moment until i get the kms up on th engine and im comfortable its a good'n (lol, and only 0.55-0.6 bar:()
My old Jap ECU had 8,000rpm from memory, and the Jap ECu for the std injectors was sky high, over 8,800rpm as i never reached it:)
When its all said and done im going to try and keep it to around 7,750rpm, but will have to wait and see how the cam gears and power delivery goes...surely im only a week away from getting the car sorted
just a quick noob question ... i have GTR injectors to go into my new "to be built" engine .. how much HP/RWKW do GTR 444cc injectors support? anywhere up to 300rwkw? and will they support more if they are backed up with a rising rate fuel reg?
Thanks
Matt
will help me decide weither to sell them when my m8 upgrades from he's 660's in he;s GTR and buy them.
Good stuff, I reckon I will stick to 7600 as my rev limit, as I don't want to kill it with revs. Maybe if I get around to it I might get the head rebuilt on my spare motor and put some cams in and new valve springs etc
Chris
Thanks
Matt
The rule of thumb is 444cc injectors in a 6 cylinder = 444 bhp (around 270 rwkw).:P
Put in the injectors, Z32 AFM and PowerFC in on saturday
Big thanks to Roy and R31 POWER, without the info from you both, I would have struggled
The injector removal and installation turned out to be pretty straight forward, with only the GTR injector plugs needing a locating tab to be trimmed to get them to plug in, overall it was no more than a hour to pull the old injectors out and have the new ones in. Best thing was I turned the key and it primed very quickly, and ther was no leaks - YAY!
The resistor wiring took a little longer, mainly due to me being very cautios about which wire I snipped
I took a few pics, but as with everything my digital camera batteries run out. I have pics of the wiring loom though and what colour the injector power wire is etc
After the resistor was wired in, I started it with the stock computer - to my surprise it fired first crank - at least it started, but as expected ran mega rich!
I did this becasue I wanted to make sure - before the PowerFC went in - that it ran, becasue if it didn't there would be to many things I have cahnged to work out what was wrong if it didn't!
Next was the Z32 AFM wiring, which was by far the easiest part of all the wiring
And then the PowerFC install, which was even easier!
It all started no probs, and is as drivable as before with the fuel/inj correction adjusted to suit
Its being booked in today for tuning, so hopefully by the end of the week!
Best of all, it all worked, I didn't drop or loose one bolt (very rare for me!), the only mis-hap was a slightly wayward screw driving finding its way into my index finger while try to prise of a very stubborn injector clip! :)
Huge thanks to everyone who has contributed, without the extensive SAU crew to fire q's at, I would have never got it done
:):D
Chris
Good to hear Chris.Are you hoping for 300+rwhp?
Yeah, hopefully, but I will be happy as long is it has a decent tune and can be driven hard without leaning out
I made 200rwkw (268rwhp) with the stock injectors and 0.9bar boost, so talking to Shaun at Boostworx, who will be tuning it, he reckons around 18psi or there abouts should see if make some really good power, and there is no reason why is shouldn't be able to run this boost, as the RB20 has lowish comp. ratio and it has a nice fuel setup now, so all the key factors are there to produce good power
Also with the previous tune it was lacking a fair bit of timing through the mid-range, and would come onto boost at around 4-4500rpm depending on load, now it starts to boost just under 3000rpm, so it should have allot more response than before
Hopefully at 1bar for daily duties I can have a responsive 200rwkw and when I want too I can up the boost and have a bit more
Looking forward to getting it all finished!
P.S, keep a eye on your postbox :D
Chris
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
