Hi Justin, I bought the Quaife and have been talking to some blokes that are using/going to use 2 other mods they say go together, BUT I may have misunderstood.
1. TSC, I guess the TSC can be used to add the power to the wheels when you want them to have in any given situation
2. add a couple of plates to the trannie, it will transfer the power to the front quicker than the stock setup.
As I respect these blokes I will give it a go and see what happens, I figure if you do not try you will never know,haha
The build should start in about 3 weeks and hoping for around 400awkw with grunt down low , it is killing me waiting as I have everything ready to be installed. :yes: :yes:
Just had the Advan RS-Ds put on :wub: , what do you think??
  • 2 months later...
REVIVE!
How come more people don't go for front AND rear Quaifes? Most only speak about front diffs.
I am interested in the upgrade, and given the comments about needing to do both, I was wondering which rear option was best. Only doing occasional track days and is a weekend car.
And what does the transfer case need? Just a rebuild - or specific mods?
Cheers,
Nick
Hi Nick
I am having the Quaife front diff and the trannie mods but have a Nismo 2-way LSD back in already, so I guess I will see how it all goes together, but I am not a race boy but I am sure there are a few blokes here that have already done it, maybe not the Quaife back diff yet.
I think most are waiting for others to try the Quaife back diff as it is reasonably new to the scene and has no track record but I guess if it is as good as the front seems to be from all reports they will start using the combo .
The Trannie mods seem to be adding some extra plates but can be arranged to give different response depending on how the plates are arranged and what you want. There is a web site here somewhere and if I find it I will put it in a post for you to look at :)
REVIVE!
Cheers,
Nick
Because the Quaife rear was only released last year. I know of one bloke that went from the Nismo GT pro in the rear to a quaife and loves it. He also has the quaife front and extra friction plates in the transfer case.
Thanks for the responses. I suppose it would be night and day going from an active LSD (in the VSpec) to a proper mechanical diff in the rear. Then I need to find a non-Vspec diff case.
I'm getting my sump extended and thought it would be a good time to get the front diff changed. But it seems I should do both at the same time.
Found good pricing on the Quaife from the US : http://www.frsport.com/Quaife-QDF3L-ATB-Differential-Nissan-Skyline-GTR-R33-R34-front_p_29114.html
Works out about A$1500 shipped, vs NZ and UK which were over A$1700.
Just be a bit careful with your US pricing.
Don't forget to:
Add 20% because our dollars sucks.
Add postage.
Add 10% GST to all that.
Add customs fees (Sometimes).
Add 3% if you are paying by credit card.
Gets pretty close to the local price.
I paid $1854 delivered for mine from Just Jap but it was mid July and the $ was stronger, so $1500 is great now if it includes everything :)
Nah its this:
http://www.frsport.com/Quaife-QDF14L-Rear-ATB-Differential---Nissan-Skyline-GTR-R32-R33-R34_p_350323.html
Plus postage which is over $100 for me. So say $1350US which is about $1630 AUD. Then you add 10% GST and you have $1800 anyway. So why not buy local.
Yeh, the front diff is US$1,114 + 135 shipping = US$1249 = A$1,513 (using my trusty 28 degrees mastercard which doesn't have fees).
So its a $250-300 freeroll - if i get charged GST its the same price as JustJap, if I don't I'm up $300 which I can spend on some cam gears.
Hope it works in your favour :yes:
From the reports on the front diff I would expect nothing less from the back, especially with the warranty they offer
How is the 350GT going, had the " Dec 02" 350GT Skyline until a month ago ,.I put the APS TT system on it, it was a sleeper and surprised a few blokes out there, now my Son has it, I should have held onto it until my R34 came back from the build, miss not having a fun car to play with. :yucky:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
