Hi guys,
I read a few threads about the quaife diff but hasn't found any feedback on its drivability on the road compared to the stock diff. It would be great if anyone can answer these questions:
Is it noisier than the stock diff ?
Does it lock up when you try to u turn on the street ?
Does it make the turning radius wider ?
Thanks
  • 3 months later...
Got my Quaife front diff a while ago. But about to install it soon. I just want to double check before I install it. If my rear is an e-diff from the V-spec would it work together as the e-diff as the car was originally designed with no front diff.
Thanks
The active diff might get confused, but then again it might not. You're not messing with sensors that play a big party on determining what the rear diff does. But the general consensus is that the active diff is the biggest piece of crap ever put into a Skyline and should be replaced with a real diff before doing the front.
Thanks man. If I were to change from active diff to a real diff, I heard that I must also changed the rear diff housing, I guess from a non-vspec. By doing this what do I do with the electronics ? would it show errors on the dash board ?
  On 16/02/2016 at 7:45 AM, KiwiRS4T said:
Can't see any problem installing the Quaife in the front since the front diff is not computer controlled.
I am just afraid that since the characteristic of the front will change, the computer will affect how the rear behave.
The odds are that your V spec is not working properly anyway so just disable it and fit your Quaife to the front.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
