Reliable Service For R33 Gts-t In Brunswick/coburg/carlton - Inner North
these are some close by workshop's
dr drift/ 5/9 alick rd brooklyn 0425818755
chasers motorworks/ 4/440 dynon rd footscray 96877118
eas performance/ 11 victroy rd airport west 93302001
allsparks performance 2 beckett av east keilor 93316110
hope it helps...... :(
thanks for all those replies...
sounds like the footscray one is the closest to me (since i'm in brunswick):
although i thought there would be something closer.
cheers,
vekra
cheers,
vekra
I'd goto Chasers.
I know Jack who use to work for Chasers, is at JAK Motorsport.
But which ever suites you :unsure:
other than engine oil anf oil filter.. what else do i need to replace after buying a second hand car? transmission oil,coolant,o2 sensor?
how much does it cost for a service?? tnx
i would change the fule filter, air filter, spark plugs, brake fluid, diff oil, power steering, a/c, check the coil packs new battery
about $400-$500 using good oils.
thats the engine check the break pads, tires and suspension also.
cheers,
vekra
there are heaps of workshops around coburg, brunswick but i dont know where they are.
you asked for a good reliable shop, iv been to all four of them for different things and they are good.
i cant recommend any in your area cos i have not used them.
fuel filter = brand & cost
air filter =
brake fluid =
diff oil =
power steering =
a/c?? =
another thing..since skyline is not that cheap car can you provide a good quality brands i need to buy for the different oils.. ive got a motul for engine oil..ryco i think for oil filter.. new spark plugs ngk laser platinum something..
just new here and just wanna know this different kind of stuff that im gonna put to my car rather than pay the store do the service and put their own oils..
tnx for the input..
air filter =
brake fluid =
diff oil =
power steering =
a/c?? =
tnx for the input..
engine oil motul 300v 5 liters $125
gearbox oil motul gear300 3.6 liters $118
diff oil castrol saf-xa 1.5 liters 49$
break fluid gs610 $36
air/flue filter about 25-30$ each from repco
power steering ?
coolant ?
a/c ?
just get cheap spark plugs (bkr7e) $30
cheers,
vekra
theres other good places on teh list..
jus sayin.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
