im on HPX's and there great, much better then OEM. i noticed much less dust aswell,, and they dont fade anywhere as quick. still would like a bit more thoe...
so will change next time to the AR1M's and see how much they wear the rotors, looking at new rotors anyway.
I'm using ar1m pads in the front with standard size dba 4000 xs rotors.. They dust more then I would like and still the rotors are not big enough.. If you feel you are going to be heavy on the brakes I would def up the size.. I've got the hpx on the back with slotted rotors
im noticing since the tyre and rim upgrade that its alot harder to brake..possibly looking at a dba upgrade soon.
BTW you checked ebay U.S lately.. seen BREMBO 6 pots for $500 on there (for all 4 calipers near new :) ).. but most of them are U.S only.. probably kill us on shipping. but i did see one auction with complete rotors and 6 pot brembo's with brand new lines for $900. cheap as mustard. to suit a 350z.. dare say thats us.
and on a random note - my rear left suspension has started to creak.. dammit - hope its not those springs spoolin! :) (but could be my old rear shocks , or something not greased up!)
Edited by PetroDola
Nah, just get some of those hectik Brembo covers... apparently they melt when too hot as well! Someone had some on a V35 and did a track day... full of fail.
If you have wheels (need the clearance, they'll fit behind those rays anyday), look into a R32 GT-R conversion. I have the fronts, 4 pot sumitomos, and original X-drilled rotors, Jetwreck has the same, except he got a bracket conversion to run a bigger disc- a 330mm i think?
A cheaper route than Brembo's. Prob just as good?
I'm just waiting till I get some wheels, then they'll be going on!
brembo upgrade need brackets made or anything? or do they just bolt up... I got some stuff thrown into container in US might see if I can squeeze some brembo's in.
also would they fit under CE28's?
Edited by whitestag
just from my experience i wouldnt bother buying the expensive DBA's like i did unless your upgrading your dia. and caliper size its just not worth the money.. sure the pedal feel and stopping power was improved a little.. i just reckon the money should be out into a larger fit out.. if i was doing it again thats what i would do!!
Edited by matty_M35
Sorry Alex bit hard to reply to pm as I use iPhone so it doesn't let me type in pm's. Will try to reply some time tomorrow. But to answer it. I having trouble contacting him. And not sure if one still going back and forth. Bit will explain in pm.
As for brakes, I'm happy as is. But if upgrade is cheap enough he'll who wouldn't want bigger better brakes
fair call .. good advice PM_Mad
we should probably start a m35 brake thread, for this info of clearances for rim size and what brake mods people have done to their m35's
if there isnt one already :?
Have a look through this , and look through the links. Gives a couple of options- 4 pot sumitomos(GT-R/ GTS-T) / brembos
M35 brakes
There is a bracket available to upsize the discs on the sumitomo to Brembo size. Looks like most of the conversions are not hard, but just depends on how much money you want to spend - brembos are at least 2 or 3 times as expensive- you pay for the name.
I don't think any conversion will actually fit behind stock wheels ( without spacers)
Edited by PN-Mad
I thought warped front rotors were only available as an option on the ARX :(
No, standard on the whole range...lol
My vote is for Hawk pads ... and to top it off running the R32 calipers with slotted rotors.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
