Easiest way - unplug the solenoid.
It should be located to the right of the turbo & wastegate - a small metal cylinder with two sets of vacuum lines running into it and a plug. Off the top of my head, you should see it right behind a black fluid reservoir on the passenger-side strut tower.
The DIY section about grounding the solenoid does not get rid of it - quite the opposite. It basically makes the solenoid always open - which will leak an unknown level of boost with factory ECU tuning and restrictor sizing, all depending on exhaust size, wastegate size, etc.
For me, with a 10psi wastegate actuator, the boost solenoid was leaking nearly 5psi - in-effec running my still standard turbo at 15 psi - way more than I wanted. By disconnecting the boost solenoid I get a solid 10psi. With the factory wastegate, disconnecting the solenoid you should get around 5psi.
Also note you can program the boost solenoid to some extent if you install a nistune. There are a number of threads on the nistune forums about it.
Really, a lot of this comes down to the reasons why you're wanting to disconnect it. If you're installing aftermarket boost control, you'll probably want to bypass the solenoid completely. Can you shed some more light on what you're trying to achieve?
^^^ yeah but that's with a 10psi actuator though. with the stock one of 4-5psi, grounding out the solenoid gives you 7psi on a stock exhaust. I saw a constant 10psi with a grounded solenoid and full exhaust. With the stock ecu and tune, the solenoid becomes static at around 3000rpm, so basically the same as grounding it out.
Even though nistune will show the boost solenoids duty as a 3D map, the stock values in the map make the solenoid behave in an ON/OFF way. I played with the duty to test it out (had to alter the piping as well), was basically the same as a jaycar iebc to setup, just in 3D instead of 2D.
Here are instructions on how to bypass the solenoid and adjust the bleed to acheive different boost levels (courtesy of SK):
This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses [thanks to SK]. Disconnect the two vacuum hoses from the solenoid. Then connect the boost feed (from the cross over pipe on the left of the picture) to the standard T piece. Connect one side of the T piece directly to the wastegate actuator (on the right of the picture). The remaining connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting). Make sure to put the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar. (See photo)
PS: If you want more boost you can drill out the bypass, 1.5 mm = more boost (around 0.7 bar) 1.75mm = a bit more (around 1.0 bar).
OK, this is the picture of the vacuum hoses. The boost pressure comes out of the intercooler return pipe (that's the big black one on the left) via the standard fitting. It travels down the vacuum hose to the standard T piece.
The right hand side of the T piece goes to the wastegate actuator via another short piece of vacuum hose. It has 2 standard spring clamps on it. So that "some" of the boost pressure goes to the wastegate actuator.
The left hand side of the T piece is connected to another (longer) piece of vacuum hose that goes to the standard fitting on the BOV return pipe. You can't see that fitting in the picture as it is hidden by the (big black) turbo to intercooler pipe. I squeezed the standard restrictor into that vacuum hose, it is tight fit, so be patient and use some lubricant (RP7 in my case).
The restrictor limits the amount of boost pressure that is bled off, so that the "some" pressure that goes to the wastegate actuator is actually less than the boost pressure. This means you get more boost before the wastegate opens at its usual 4-5 psi. How much more depends on the size of the hole in the restrictor, the bigger the hole the more it bypasses and the higher the boost.
The standard hole is ~1.25 mm and gave ~0.5 bar on my Stagea, which has standard everything else (no exhaust, no FMIC, std filter, etc). If you have mods, you may not get the same boost pressure, so you may have to adjust the size of the hole in the restrictor, it is brass so you can easily solder it up and redrill the hole smaller if necessary.
Hi thanks,I was reading the steps to get a bit more out of it,step 1, inlet, 3" exhaust,disconnect two stage boost and set the plugs at around .8 mm to remove any flat spots.I am always ready to listen to advice
Cheers
Steve
Disconnecting the solenoid will lower your power - not increase it.
GROUNDING the solenoid will increase your power below 4500rpm (as it will essentially bleed out and remove the 4500rpm solenoid switchover).
At those levels of modification, 0.8mm is also probably overkill - I wouldn't bother, and if you were having issues, I'd probably be thinking fresh coil-packs prior to a smaller plug gap. Unless you're running much higher boost, its almost certainly un-necessary and will also rob you of power.
Realistically, 3" exhaust, FMIC, ground out the solenoid (or even better - EBC), nistune + retune.
Look at things like coil-packs / plugs if you see flat-spots / mis-firing at that point. If you already have flat-spots, mis-fires, you should get that stuff sorted before trying to get more power out. Start from a solid base.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
