I'm running them in mine with nistune. only the 550's though. Idle like a dream and just pulled 291rwkw on e-flex (e70) with plenty left in them..
as long as you can adjust the Injector latency (the "turn on time") then they'll be jsut fine :blink:
And I'm positive you can adjust this on a powerfc!
these are the exact ones i got
http://cgi.ebay.com.au/SIEMENS-550CC-FUEL-...=item335f71ce57
just email him and ask for 6 instead of 8, tell him it's for the nissan and he'll chuck in the connectors
$71.50 each. for $429, great price!
Has anyone ahd any experience with these injectors for a R34 gtt with a power fc?
http://cgi.ebay.com/ebaymotors/Nissan-Skyl...sQ5fAccessories
Cheers
I bought this same kit but in 650cc. Running a nistune, not a problem
I did have problems with the cheap chinese HKS copy fuel rail
Injectors would not seal well in rail. Injectors tops had to be machined slightly to seal (mechanic did this)
Also the ends of rail were not 100% square so fuel in and out of rail was leaking. Had to machine ends sqaure.
Fitted the up to a greddy style inlet mainfols on a Neo 25.
nar no need for the fuel pressure regulator. But you will need to upgrade your fuel pump if your gonna make good use of the size of the injectors
I've heard nothing but good things from croydon.
I'm in the ACT so i can't really help out much more than that.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
