Need A Stock Exhaust Vic Guys, Help Me Out Epa!?
got a letter from EPA, looks like someone reckons my car is loud, but at 84 db limit i think all modified cars would be. anyways i need a stock exhaust for my car to pass any one have one that i could buy/borrow. need help ASAP. thanks
dave
0400552258
84? dunno just going by what the tester said, maybe i misunderstood. but he told me not to waster my money reckons it wont pass with the silincer anyways so go get a stock or give him $400 for tripple muffler setup????!!!!
did you wanna lend/sell the stock exaust alex?
Don't bother trying to pass with a modified exhaust, I thought mine was quiet...turned out to be 98db. The standard one is about 88db @ 5000rpm or something...the limit and the RPM it is tested at is nothing short of ridiculous. And the GTR as far as I know, breaks the limit in standard form. Chuck a stock one on just for the test if you want to risk it again, or get some ridiculous three muffler system for a permanent solution.
Just another example of our police force equipping servicemen with hearing abilities that would put Superman to shame. And YOU have to pay for the test :blink:
  • 3 weeks later...
Just another example of our police force equipping servicemen with hearing abilities that would put Superman to shame. And YOU have to pay for the test ;)
and no repercussions when they're actually wrong,
would you prefer a noise test on the spot? What if you fail then? Then there is no reason not to issue you a fine or say the car is undriveable from that moment.
At least with the current system, you can change it back to standard and then go to to noise test
Sure you get done for a $xx test fee but I believe its better than any possible on-the-spot fine if they do testing when they pull you over.
(this all based on cop issuing noise epa notice)
std r32 gtst exhaust is 89db so anything modified will be over the limit. Majority of skyline drivers would be over the limit unless they spent money on a custom silent exhaust.
yup, i dont really mind a fine on the spot, but then again, for an accurate noise test, there are a lot of requirements that have to be met... so. any reading that's taken by the side of the road, where there are trees and shit, can be disputed, no?
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
