Yeah I'll reset it tonight and see what difference that makes, to be fair I have played with quite a few settings :)
To be honest, I'd expect that even "crappy" kit lenses should smash a basic point and shooter without needing to be a pro photographer to make it so.
We'll see what resetting the settings does. I might also do some testing with the 55-200
  • Replies 64
to be honest, i dont see a problem with those shots. The problem might be the picture you see isn't what you were trying to capture, or your expectations from the camera in auto mode.
There's more settings, more options, more information. It's kinda like the difference between describing something to someone who knows nothing, or describing it to an expert.
Like explaining a car to your girlfriend (Point and shoot) It's a red car and it's new.
'cool'
Or to an expert it's a red car and it's news
'what make model?'
what year?
what mods?
power output?
RWD?
blah blah
you need to fill in more blanks to paint a richer picture or tell a more detailed story.
Yeah I get what you're saying.
Am I the only one who thinks that on "actual size" the engine bay of the car doesn't look that clear or that the pictures of the book look a little soft around the edges? Surely that's not being too picky?
I guess I was under the impression that given the camera has a much wider ange of settings to choose from it would be smart enough to outdo a point and shoot on auto in most situations.
By actual size you mean when zoomed into 1:1? I'll be amazed if you can find any kit lens (or any P&S) that can produce sharp clear pics at 1:1 crop
Yes it can - maybe do exactly what you said - do some side by side auto tests (making sure settings are reset) - then go from there
OR if you care that much you could always do something crazy like getting a good lens for $137
then you can do some side by side comparisons at 50mm between the 50mm lens and the 18-55mm kit lens :)
The dog and car shot were daytime and well lit, the book shot was around 6pm but under the pergola.
I've found that without the flash It's almost impossible to get a good shot in low lit indoor scenarios so far, I wasn't overly impressed by the fill of the flash either, and by fill I mean how deep into the photo it can light up. (Trying to take photos of someone doing a speech from a respectable distance for example)
But we'll get to that :)
Your file download should start immediately.
If it does not start automatically, please click here to start the download process.
man just host pics with photobucket and copy IMG tags in here.
i actually prefer file hosting over image sharing, at least they don't fuck with your photo and ruin the metadata etc.
No idea about flickr as I dont use it.. But never had a problem with photobucket ever.
Dan - just open up image in lightroom or photoshop. Resize to 1024 max width or height.. then apply slight sharpen and save as srgb jpeg.
Perhaps your uploading rgb format images. If thats the case then colours will look off. srgb is best view on web browsers.
Then upload to photobucket (which is free). Then just copy the IMG tag link in here. Saves people clicking on links and downloading each image.
my 2 cents.
Edit: how is flickr altering your image? As in what happens?? Millions of people use flickr so doubt it is.
Edited by siddr20
Happy to do that next time, but I'm not about to go back and do it for these ones unless the consensus is it's killing people horribly to click the current links lol
there's that laziness coming out..
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
