Yeah don't think it's the camera, it's definitely me and my expectations.
The other thing I completely forgot about is that camera's are not the human eye when it comes to focus. What I mean is I was expecting to be able to take a shot like that that has very different depth throughout the shot whilst keeping everything in focus.
But when I thought about it from a camera point of view it makes sense that only objects that share a particular depth within the shot can be in focus at any one time. Is there some trick to taking a shot like that and having as much as possible in focus?
When playing with manual focus points I was able to get the knife block in focus and the bench etc at the same depth point but of course the background is then quite out of focus.
+1 for wanting a new/better flash.
  • Replies 64
Yep, the key there is the aperture you're using.
Smaller f-stop number = larger aperture, but quicker shutter speed = less in focus;
Larger f-stop number = smaller aperture, but longer shutter speed = more in focus.
Smaller apertures are great for taking macro shots or photos where you only want the focus on a certain part of the shot and everything else blurred, whereas larger apertures are for when you want more of the image in focus, which is probably what you're trying to achieve in your kitchen shot.
You've used apertures between f/3.5 and f/5.0 for those kitchen shots, but if you were to take them again at between f/8 and f/11, you'll notice the difference. Just about everything should be in focus if you choose something around f/22
I imagine then problem at something like f/22 which you said means longer shutter speeds becomes motion blur if I was going hand held. So a tripod might be something we need to look at as well.
Sometimes I actually think a good point and shoot can match these things when using auto settings or for when taking shots at parties in low light conditions etc.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
