R32 Gtr Odds And Sods
Bonnet Hinges - $20
Rear window wiper motor - $30
Fuse box area aircon vent - $60
A/C Condensor Fan - $50
Centre console "tunnel" type thing at rear of radio to floor? - $45
Aircon Temp Sensor - $20
Boost sensor - $15
Side Repeator lights ( Orange - Amber ) $20ea or $30 both
Pedals Accelerator, Clutch, Brake with all brackets $100 for the set "GTR" rubber in good cond.
Odometer Cable - $20
Air Con Control (DIN size unit under radio) - $80
Std. Exhaust Manifolds - $70
Exhaust temp sensor - $20
HKS "Mushroom" Filter kit fits to std. AFMS - $70
ATTESSA oil Res. - $30
more to come msg me on 0422 648 745 prices neg. message me with listed price and your offer.
Buyer pays for postage if Aplicable.
-Daniel
RB26DETT Valve caps - $40
Thermostat housing $30 and other side casting for radiator $30 also
Seat belts $200 set or $60ea
Std. RB26DETT ignition Coils $100
Pwr Steering Fluid Res. W/ Lid and wiring - $50
Charcoal Canister (Transaction Aus Carbon) -$40
Coolant Res. - $50
Winscreen washer res W/Pumps - $70
Some Std. FMIC piping $40 Lot
Wiring loom (Cabin Fusebox loom) W/fuse box and all fuses/relays - $150
"Twin Turbo" Pipe RB26DETT - $80
ABS Unit $200
Aircon Vent (Centre Dbl. vent) $70
Fuel Cap Cover W/ hinge (Gun metal Grey) $20
Starter Motor - $40
Bonnet Release Cable - $20
Tail Lights - $70 ea
Boot lid Rubber Seal - $40
Engine Mounts L + R $40 ea
Passenger side reverse light - $40
Cam Position Sensor - $50
Std. Cam Gears - $30 Pair
Std RB26dett Cams $180
Fuel Rail - $60
A/C Condensor - $50
Pwr steering fluid cooler - $30
Flywheel - $100
RB26DETT Sump and diff $180
Steering column W/ Ign Barrel + Keys - $300
Engine Crossmember - $150
Steering Rack + lines - $100
RB26DETT Head Studs - $60
Accel. cable - $20
Passengers A pillar - $30
Clutch Fan - $40
Boot Hinge + Springs - $60
Front Sway Bar Std. - $60
Passenger Steering bar thing from rack to hub - $20
Air Comp. - $60
Passenger Door (Red / Burgundy) W/Window, no card or handle $200
Drivers door (Gun metal Grey) Wwindow, no card - $210
RB26DETT Cylinder Head 1 piston gave up and shattered so 1 cylinder has mashed valves and rough suface may be repairable -$40 pickup only
RB26DETT Block (1 missing piston, Bent rod, and has bashed through that sleeve) 5 pistons left with rods, Crank and large pulley part open to offers
Throttle Position Sensor - $40
Injector wiring loom cover (Black plastic) - $20
Rb26dett dip stick - $10
Centre Light (Roof) $20
Dash Cluster - 180kms model, $100
Dash Surround, with all switches gd cond no cracks $100
  • 2 months later...
 Share
