Hi
I'm in the process of importing a 1999 RS4S through Iron Chef and have a couple of questions about some parts I have been thinking about adding but I'm not sure if they are street legal here in Tassie or not, so I'm hoping someone might be able to help out. Can anyone tell me if a carbon fibre bonnet is legal? Or a Varex exhaust?
Thanks
Tim
https://www.sau.com.au/forums/topic/343488-modification-questions/
<br />Just ring service Tas to confirm legality of the cf bonnet . how big is the exhaust ? usually have to fit a pretty stock exhaust for compliance .<br /><br />
<br /><br /><br />
The car looks to have a 2.5 or 3 inch exhaust system on it (just waiting on exact details), but I'm thinking about fitting one of those Varex mufflers with the valve that you can open or close to make it loud or quiet, and I'm not sure how legal they are
<br /><br /><br /><br /><br /><br />The car looks to have a 2.5 or 3 inch exhaust system on it (just waiting on exact details), but I'm thinking about fitting one of those Varex mufflers with the valve that you can open or close to make it loud or quiet, and I'm not sure how legal they are<br />
<br /><br /><br />
Update - just spoke to Service Tas and the guy I spoke to did not think the bonnet would be approved because of the potential impact on crumple zones and the car's safety system, but that the Varex muffler should be ok as long as it complied with volume limits.
Any thoughts/experience that anyone else has about cf bonnets or the volume of Varex mufflers would be still be appreciated!
Hi
Thanks
Tim
good to hear another manual in tas, I think we have the most manual stagea's per state then any other!! you located south, north or coast?
I'm in Launceston, can't wait for the car to get here!
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
