GO to Drag Combat...RACE at Drag Combat
OK! All SAU members: This is an event tailor made for Jap Imports from stock right through to over-the-top mods. Last year was a blast!!! mick51 got 16 yes 16 runs in....makes the average t & t look sick. They need our support to make this a success and therefor an annual event so if we want recognition and acceptance of our cars we need this kind of publicity + You will be on TV, Fox Sport will be there and will broadcat the event on 8 occasions through the year.
So all you guys who intend to do drag when you've done this or done that to your car tuck you'r balls in and put in an entry, or at least come and support us guys who are entering.
My car is in,with mick51 driving again but is a bit touch and go as to whether I can get it ready in time.(balancing on one leg)
Perhaps we can co-ordinate with strutto to get a mass SAU arrival, though competiters need to get there earlier.
Look forward to seeing you all there
http://www.dragcombat.com
https://www.sau.com.au/forums/topic/34349-go-to-drag-combatrace-at-drag-combat/
Dragging is great fun, and very little chance of killing your car for those that haven't done it... so don't be scared - get out there!!
No money, no drag, no helmet, no fun :cheers: so unfortunately I can't make it onto the track in my goal of getting a blistering 13.7s 1/4 mile :), but I was planning on coming down to spectate with everybody.
Exactly Jay... Take it to the track... Mods don't mean shit unless you've got the timeslip to prove it...
Are entries still open? Price?
What sort of racing is it? Heads up? Bracket?
Are you sure we won't be laughed out the gates if we run 14's all day? :cheers:
I'm defineatly gunna be there as a spec... you might have to twist my rubber arm to get me to race though...
Unfortunately it's quite exxy....$80 but that gets another person in for free so work it out......2 people spectating= $60 1 driver+1 crew=$80... your getting a days racing....as much chance as anyone else to win money....and your car on TV ....all for $20.
We would be Bracket racing ...pick your et and stick to it 2 classes ET1 0 to 11.99 and ET2 12 to 14.99. mick ran mid 14's + acouple of 15's last year we are hoping to be into high 12's this year.
Old turbo is just about off, HKS 2540 ready to go on........ITHINK we're going to make it....as of today I start partial weight bearing on my poor little foot. Should make things a little easier!!
I hate you all , I so wish I was there
There will be drags up here in Tvl , but you know it's not the same . All those that have not been to one , you must go it is a time to go see sick cars and what they can do , not just ones sitting in a show room looking good , that is cool too though
I had entered, paid my fee & was ready to go, but alas, blew a turbo going home on Friday arvo (ironically after picking it up with the Motec installed)....
Oh well, there's always Jambo & next year....
Have a good day all
Cam
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
