need an electronic boost controller to stop boost spikes but i dont have much cash at the moment.
been looking on ebay and just wondering if anyone has tried these ones and what they thought???
http://cgi.ebay.com.au/JDM-Multi-Function-...=item2a08fd734d
https://www.sau.com.au/forums/topic/343510-boost-controllers/
If you are getting boost spikes with no boost controller it wont help, it is your gate setup that is causing it, boost controllers can only make the boost come on faster and higher, cant lower it or make it slower.
What are you currently using for boost control and what is your turbo setup?
Edited by Rolls
its just got a shitty turbosmart bleed valve. just running the stock N1 turbos.
fingers cross its just the bleed valve causing it. i really dont wanna go chasing problems.
starting to wish i kept the V8!!!
Get rid of the bleed valve and get an EBC, eboost street are around $400 and very good, as good as any of the other brand name ones for $600+
You could also try reducing the line size on the bleed valve, the mechanical ones often spike if they have more than 10cm of line on them, when I first got my first turbo car it had almost a metre of line, spiked to 16psi then dropped to 10 on the lowest setting with a turbo smart one, cut the lines right back and it got a lot better but still spiked.
EBC is the only way to go, a stock GTR controller should let you run 10psi quite easily and this is all you want to run max anyway if you dont have supporting mods, if you do then EBC it up.
hey sorry to take your thread but does any one know about an ebc that will have a high/low boost button.
ie. press the button remote mounted and your car goes to 20 psi until button if pressed again, then boost goes to 12psi.
not the turn and push because to have the car leagel in qld you cant have a in cabin ebc. may get around the boost controler in cabin senario by putting the controler in the bay or deep inside the dash and just hiding the solenoid. yeah sorry about the hijack but this may be used in future by me.
David
As Nismoid said get a turbotech boost controller so many people have used them with 0 issues (me included) they even do an electronic kit now for like $80. It's all on ebay not sure how their electronic kit works but if it's anything like the MBC it will be very good
David
pretty much all have different boost settings where you can just press a button, just cut the ass out of your ashtray and mount it in there, easy access and no one will ever see it, thats what I did
Benefit of Dual over single solenoid ?
Dual's tend to hold boost more reliably and tend to reduce any boost spikes caused by the EBC itself.
As they are Dual Solenoid they can meter/read from two sources therefore have a more reliable reading.
David
Turbosmart eboosts can have a remote mounted switch wired to earth that changes between boost groups.
Get a decent ebc man, your standard nismo turbos are good for 20psi mine are anyway. Im making 300kw on 18psi. Get the ebc and a PFC and send me a PM. I can get you good dyne time at a good price
David
gizzmo ebc allows a remote button to switch profiles or overboost for x no. of seconds
thanks will keep that in mind
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
