Up forsale is a 2003 carribean blue V35 premium 6spd manual coupe. Comes with factory Brembo brakes, dual zone climate control etc. Ive owned this car for almost 3 years and purchased it completely stock with only 25xxxklm on the clock. It now has 51xxxklm on it and has been serviced every 5000klm using full sythetic oils only. There are no log books but i have all service reciepts and Greg from Autosport can vouch for the klm. In this time all oils have been replaced engine/gearbox/diff etc with no expense spared.
INTERIOR
-Factory leather/suede interior
-Aftermarket IPOD connectivity
-Aus FM transmitter fitted to radio
-Genuine nismo carbon shift knob
-LED interior lights
-Genuine nismo floor mats front and back
-skyline aluminum door sills
DRIVETRAIN/SUSPENSION/BRAKES
-B&M short shifter kit
-SPC rear camber kit
-Pedders extreme xa coilovers (still 12 months warranty left)
-Cross drilled & slotted rotors front and back
-Hawk hps pads front and back
-Stoptech braided lines - front only
EXTERIOR
-Work varianza t1s in lightning silver with step lip, 20x9.5 +5 Front, 20x10.5 +0 rear. Fronts suit BBK and Rears are the deep dish disk. Work RS-R extended open ended wheel lock nuts in anodized blue. These wheels took 3 months to get delivered and cost over 5.5k with lock nuts and tyres.
-Falken fk452 tyres all round, 245/35 front and 275/30 rear (90% tread) these tyre sizes were the closet i could get to stock rolling diameter without affecting speedo to much if any.
-Guards extensively rolled/lipped by nelson from sydney guard rolling with no cracking issues what so ever.
-genuine jp visage front lip imported from the states
-genuine stillen rear roof wing
-rear splash guards
-rear end completey shaved/debaged and completely re sprayed
-all bodywork and painting done by xclusive colours less than 4 months ago.
-JDM 06-07 rear tailights
-led number plate lights
ENGINE
-JWT pop charger with heat shield
-Z tube
-NRG carbon fibre hood dampers
-Unorthodox racing pulleys and belts
-Motordyne 5/16 iso plenum spacer
-platinum spark plugs
-STRUP stainless steel headers (took 6 hours to install)
-Berk stainless hi flow cats
-Motordyne shockwave dual Exhaust with xyz pipe and resonator and titanium tips
-Stillen red grounding kit
-Haltech platinum interceptor piggy back fitted and tuned by CRD, dyno sheet provided
Car made 179rwkw's with kakimoto cat back, would guess it would be more like 185rwkw now with the MD exhaust, maybe more with a retune.
All parts fitted by Greg at autosport engineering.
PROBLEMS
- CD player does not work, however does have ipod connection and aus fm transmitter fitted
- scratch on the bottom right corner of the front lip.....basically cant see it unless you lie on the ground
- small wear and tear on drivers seat - will post pics up this week.
- only have 1 set of keys....thats all i was given
- Right hand side exhaust tip doesnt quite line up with the factory bumper. Tony from Motordyne is sending me out a replacement right hand side axle back which will be provided when he gets the stock in.
Apart from these the car is in immaculate condition inside and out. The car turns heads wherever it goes and drives perfectly.
Any inspection welcome.
PRICE
- $35000, OR $30000 with stock wheels.
Not interested in selling any parts at this stage, would rather sell as is and please NO SWAPS.
All standard parts are included in the price from stock airbox/filter to stock wheels and brakes etc. Only standard part i dont have is the catback exhaust.
All parts fitted are less than 10000klm old, most even less!
Will place many more pics throughout the week.
Located Maroubra NSW
Please PM or email with any questions or call Michael on 0422172482
Edited by robbo33
  • 1 month later...
  • 1 month later...
best advice on this one mate is to revert it to stock and sell it that way and then sell the mods separately.
These things are really hard to shift (i know because i have an immaculate stock 06 premium with 36k km on it that i tried to shift with no luck at all).
You might do it eventually, but only if you find someone who really cares about the mods, with most 03's going for low $20's its a buyers market.
Hopefully you can get rid of the car that way and them sell that parts on here for your asking price or more.
That said, good luck with the sale.
  • 1 month later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
