Hey All,
Well i am very happy to say, thanks to the guys at GT Auto Garage, i have my 32gtr back on the road again after about a 6yr absence. It was an extremely big decision to take the path i have with the build, but i am glad i made the choice.
I originally bought my R back in about 2003 after owning a r32 gtst for about 1yr. When it arrived in the country it had some aftermarket parts already fitted and i enjoyed it like this for about 4months, before carnage :P lol as any gtr owner will understand.
The first problem came about from a spun bearing, piston 5 having no ring lands left at all and the rear turbo non existant. Probably should not have turned up the boost controller so far..... hehe.
After difficulties with 2 workshops a good friend of mind suggested i talk to Alex and the guys at GT Auto Garage for help and advice on setup and future plans. Over a few weeks we came with the current setup choice and am extremely happy with the outcome.
ENGINE & ACCESSORIES
- Step 2 HKS 2.8Lt kit (crank, rods, pistons, head gasket etc)
- Step 2 HKS head. (cnc machined in. & ex. ports, oversized valves all carried out by HKS JPN)
- HKS camshafts 272deg in. 280deg ex.
- HKS cam gears
- HKS fine tune timing belt
- HKS oil pump
- HKS oil cap
- Greddy Sump extension and baffles
- Greddy Oil Cooler and remote mount oil filter
- Greddy Aluminium radiator
- Greddy Radiator Cap
- Greddy Lightweight Pully kit
- N1 water pump
- ATI harmonic balancer
- HKS twin power ignition
- Splitfire Coils packs
- Dual SPAL 10’ thermo fans
- SARD 1000cc injectors
- SARD billet fuel rail
- SARD rising rate fuel regulator
- GT AUTO custom surge tank
- Dual Bosch 044 external pumps
- HKS Fcon V Pro ECU
TURBO, EXHAUST & INTAKE
- Trust T88-34d turbo kit inc manifold & wastegate
- Greddy Drag Intercooler 600x300x150
- Greddy Plenum & oversized throttles(6)
- Trust Airix air filter
- GT Auto custom 4" intake
- HKS racing bov
- GT Auto custom S/S wrapped downpipe
- HKS silent HiPower Exhaust
DRIVELINE
- Stock gearbox (upgrade pending)
- NPC twin plate clutch
- Upgraded diffs. spec unknown
BRAKES & SUSPENSION
- DBA 4000 rotors (full f&r upgrade pending)
- Upgraded pads
- Braided brake lines
- APEXi N1 dampers (coil overs)
- Nismo adj arms
- HKS/Kansai Service tower bars
WHEELS & TYRES
- R34 GTR Wheels – 18x9 +30 powdercoated in satin black
- Bridgestone Potenza RE55 semi slicks 265/35/18
BODYWORK
- Genuine N1 Front bar with “Rocket Dancer” carbon fibre lip
- Fujimura Auto Carbon Bonnet
- Garage Defend Carbon cooling panel
- N1 side skirts
- Standard rear bar
- Top Secret style rear diffuser
- Veilside GT2 carbon fibre wing
- LED Tail lights
INTERIOR
- 7-point bolt in roll cage
- Veilside 340km & 11,000rpm white faced dash & aux meters
- Veilside VSD1 fixed back seats
- Veilside combat steering wheel
- Veilside combat shift knob
- HKS Evc6 boost controller
- Gizzmo dual stage shift light
Thanks for looking. Comments and advice welcome.
I will take some more pics in the coming days as i don't have very many. These are taken on the weekend i got it back which quite a few months ago now.
Mike.
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/
Yes BLUR, i think i owe you something for the great suggestion. Im soo swamped with work atm its crazy, ive had no chance to get to see the guys and talk about those upgrades. Ive sent some emails back and foward with Holinger to find out what they would suggest.
Im just itching to see how it goes at QR....
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5539825
Wow you'r Car is amazing, 2.8 KIT :) ... I also have to go to them for Tuning when my R arrives this month, initially i had to go GT Auto as there are the only shop with HKS F-COn, but after reading your build, i will go there with lot more appreciation and knowing there Top notch place
PS - Not a big fan of the rear wing... i am sure you need it though with a monster like this
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5539864
maclarenf1 - id prefer to have something on there than not at all for when i do go to QR...lol
but after seeing a couple of their cars and the workmanship on their FD, the decision to spend a lot of money with them was quite simple. They are maticulous in what they do and the approach to customers if first class.
GTRAAH - i bout the led units about 4yrs ago from jpn. all i did was remove the standard white outer cover and made sure it all fitted correctly, then sicker-flexed and screwed it back into the rear panel making sure it all lined up correctly. this process took q couple of weekends till i was satified. Still thinking of going back to red led's tho...
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5540002
hahaha, well i don't have a carbon grille anymore :unsure:
changing to carbon panel's have been in the back of my head.... but if i go that far the car will no longer be registered and im not sure i like that idea...lol
Edited by dahandfull
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5541906
I am a big fan of that fuel system setup :(
This would be a great package to punt around and QR's back straight would let you get a big head of steam up so definitely bigger brakes there lol
Keen to follow this one
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5542846
thanks Weapon....
im not sure punting around is the correct term there :( ...... its a massive handfull at the moment due to how early it makes its power and more importantly the delivery of the torque. Yes, definately a big set of 6pots is a must before i attack QR...
Thanks for your feedback.
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5543064
BOOST31 - Thanks bud.... Ive tried to keep it pretty unique while looking truely JDM style :D lol
What i like the best about it is we are still using pump fuel & we havn't even cracked 20psi yet to make all this power & torque. I want to run a few more km's before that happens. 25+ and e85...... oh dear!! :)
https://www.sau.com.au/forums/topic/343513-mikes-r32-gtr/#findComment-5551975
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
