Hey guys,
Decided to go for the more sensible option and purchased a new Corolla. So my Soarer has to go! Its been a good car for the past 5 years since ive owned it, but now its time for it to go!!
1991 Lexus Soarer (sc400)
176,xxx kms (strong motor)
Blue
NO REGO - Just expired a few days ago (still have 3 months to re reg it without inspection)
NO RWC
Interior is in decent condition however there are a few cosmetic issues with the door trim etc
Exterior has a few scrapes and dents etc as can be seen in the pics below. Also missing the left side mirror but i have a replacement one you can have!....tree fell on my car! boooo
Engine runs perfectly, ive always serviced it at toyota and had the water pump and anything else that was needed replaced... got receipts to prove.
Basically i just need it gone, which is why it is up for a good price. Needs a bit of tlc cosmetically but otherwise it is a very good car!
$3500
Andrew 0431 222 796
South Eastern Suburbs VIC
Pics:
Edited by hoy32
https://www.sau.com.au/forums/topic/343527-1991-lexus-sc400-soarer-melb-3500/
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
