Hi guys, just did a turbo conversion on my rb25.
Now the car was running tops before the conversion, chucked a new manifold, turbo, braded lines etc on to it and started it up. No tune, no driving, just idling and the coolant started foaming up out of the radiator. It is quite a thick white/browny foam.
Now when the turbo was done, the coolant drained out of the turbo water line and would have been fairly low. I topped it up with water before starting but the thermostat wouldnt have opened. Have not topped it up and bled it since.
I checked the engine oil, inside rocker covers etc. and am pretty sure (well, from what i can tell) the head gasket is ok. Remember, the car hasnt been driven at all, just idling and a quick rev or two when it warmed up.
Reckon it would have just been the low coolant? Flush it out a couple times then fill it up and bleed properly?
Edited by SkyHi_33
https://www.sau.com.au/forums/topic/343562-coolant-foaming-up/
you hooked the oil/coolant lines up correctly?
yeah double checked that... oil feed is mid way through the block, return on the bottom? water line off the intake manifold, return towards the back of the block?
yep.
oil feed is close to inline with the return half way up the block, return is just above the sump. water is from the intake side of the block on the rear heater hose fitting, and on the exhaust side near the back of the block.
do you have any pictures of the foam?
nah just a standard 33 radiator... no pictures of the foam unfortunately. was running around making sure there werent any leaks etc and didnt get a chance to take a pic.
ive had a quick search and smeone mentioned that it can happen when the coolant is very low, the water pump pumps air through it and foams it up :S
Could it be a leak in the turbo seal causing air to get into the system? check the exhaust doesn't have coolant and isn't steaming.
Other option could be air has got into the system during installation, leave it idling for a few minutes until the thermostat opens up and see what happens, you won't kill anything at idle.
This is assuming the foam is just air and not the coolant mixing with oil or something else.
Edited by Rolls
had it idiling for about 15min before, exhaust is clean, no smoke (bit of condensation at start as its been sitting around) the coolant is greeny brown and started foaming up before but seems like its slowly clearing up.
have not had the chance to bleed the coolant system yet as its in the garage blocked off by other cars (dont wanna make a huge mess) but will try do it during the week. i did let the thermostat open and topped it up some more tho.
checked the engine oil after i shut it off, seems clean/normal. all lines seem fine, no leaks that i can see. turbo spools up fine just revving it and can hear it smoothly slowing down after its shut off (ball bearing) so i think its all hooked up fine.
Edited by SkyHi_33
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
