  • Replies 101
I'm not so fussed on the drive part given the stone chips I got last time I did a cotter cruise however would be nice to get all the cars together and catch up with everyone for an end of year BBQ.
Do people want a Saturday or a Sunday?
I'm in.. as long as it isnt on the weekend of 20-21Nov, 28-29Nov or 4-5Dec.. althought I might be able to make it if its on 4-5Dec. We could always do it on 27th 28th or 29th of Dec as they are all hols for me and most others.. I vote 28th Dec.. w00t cruise on bday :)
I also vote that we don't go towards Bungendore/Braidwood due to the increase five oh (I'm so gangsta!) activity due to summer and everyone else heading that way. If we can't find anywhere to cruise we should at least have a BBQ, if a location cannot be found we could have it at my house, that last couple large gatherings there were pretty successful
Edited by nerm
Yeah I can't do 4-5 Dec. I'm a better chance if it's a Sunday however if it's a Saturday it just depends which one and at what times.
Anything after Christmas is probably a no go for me as I'll have family shit to do.
We could just do a local cruise around Canberra, hope for a beautiful summers day. Start somewhere random (could just be Gravlia point), and finish at black mtn peninsula and have the bbq there. Or Weston Park?
5 Dec is "Chippas main street cruise"
http://www.chippasmainstreetcruz.com.au/
Ignore the fact that there's a VK on the cover. Although it is a sweet ride...
Chippa was a dear friend to me, and we hope to raise lots of money for the starlight foundation.
So everyone that wants to come to that please sign up and get amoungst it :)
So back to our own cruise.
I'd like to get out and have a bbq somewhere.
At the uriarra east reserve there's bbq's, the ones that manly men need to build fires in and get the plates hot. So that time of year they'll probably be out of action with some total fire ban rubbish...
Googong?? anyone been out that way?
In regards to the cruise part, I think if it's not the cotter, the only other place I can think of in ACT is Corin Forest. If you want to go further out, maybe out to Lake Burrinjuck, Lake George or the Coast.
There are a few nice BBQ area's around Lake Burley Griffin.
I like the idea of trashing Nim's place :)
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
