Lol, not much of a race the person doing mine takes off on holidays tomorrow hahaha
Mines got 2 mufflers aswel, other is in the box.
Still, I got the motor in the car so that has to be a headstart haha
is it actually possible for a 4" straight through muffler to really do any muffling at all? Even if the oval was 1 meter wide on its own it would still do bugger all surely?
People with more knowledge than I have in this area have sorted it out for me so it's quiet and flows like a drainpipe
I don't mind a bit of noise, just want all the flow possible. Time will tell
Having the motor on the stand is a minor detail :whistling:
Lol!
"it never ends"
Btw you know my carbon Kevlar seat, do you want it? I want a different one and want to sell this before buying another so I'm not stuck with two. You know what it's like at mine with parts and space
Not true at all, at top end when you are making that kind of power a whole lot of exhaust is bypassing the exhaust via the wastegate...
3" on 26 with T04z regularly make between 430-470rwkw
Depends if you are external or internal – either way, bigger does no harm at all.
Garrett engineers on their website clearly state that the less restriction after the turbo the better. Sure this needs to be weighed up with physical limitations and noise levels etc. But a greater flowing exhaust can only improve response and top end power. Obviously, whether its even noticeable depends on your power levels but at 400rwkw I think it would be very noticeable.
Just because some cars manage to get 400rwkw through a 3" exhaust doesnt mean they couldnt be a heap better with a larger exhaust.
Min 3.5" IMO
Couldn’t agree more.
I’ve seen cars make 350rwkw with a 3” as well. Swap it over to a 3.5” and boom, another 15-20rwkw and better midrange. Some are users here (some have also posted, which is good)
Just because it makes the power, you can get a 3” to 400rwkw no problems, doesn’t mean that putting something bigger will not provide benefit.
Well with 2x 3.5” straight through mufflers (they are massive), I’m around what, 90dB, so it must be possible :whistling:
Mufflers weren’t cheap, but they certainly have some effect.
would there be any power gains for a 170rwkw by changing from 3" to 3.5" cat back but keep the 3" dump/front/cat?
no mufflers btw
Not really no, 3” with little bends and straight through mufflers is plenty for up to 250-300rwkw.
All you get is noise @ that level.
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
