I need to know what the minimum octane rating is for an M35 stagea.
I'm getting a fuel card at work and have to justify using premium petrol by photo copying the workshop manual or something similar.
Any suggestions?
Feel free to include C34's as well. (we're a sharing bunch.. :P )
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/
I used 95 octane in mine for the first winter I owned it, then switched to 98 when summer arrived. They just run so much nicer on 98 I never went back. I don't even use E10 in my missus mazda 323, it's just horrible.
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/#findComment-5540848
Any suggestions?
My ARX has at least one sticker stating RON98 but I am too lazy to go out and check.
Import work shop said the computer in them is dam smart and can cope all the way down to 91 just runs rich so you go through fuel and loose power.
Anyone tried?
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/#findComment-5541018
:) 98 all the way!!
There is no car currently sold in Australia that the engineers have designed for 91 octane....
Even the AUS designed vehicles are optimised for at least 95 octane as that is used for emissions and fuel consumption testing...
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/#findComment-5541192
Thanks for the responses guys.
I have a copy of the S15 SR20DET manual (I needed it for my Datsun). It says use 95 RON.
Anyone have a copy of the workshop manual/service manual which states 98 or 100RON?
I've downloaded a couple of the PDF's for an M35 and couldn't find anything.
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/#findComment-5541540
err no dont use anything except 98RON. they should be run on 100RON but shell dont sell that anymore.
:unsure: 98 all the way!!
:P agrees.... although you can use 95 in a pinch
*Cough* E100 :blink:
Get out of here Greenie!
M35 workshop manual is HERE, dunno if it mentions anything about octane or not
https://www.sau.com.au/forums/topic/343655-m35-stagea-fuel/#findComment-5541717
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
