Hi All,
I'm stuck i'm looking to replace the bushing in my 2004 V35 skyline, it's the bushing on the black arm below. Does anyone know where I can get this from in Australia and where I can get it replaced? Does whiteline make theses bushings?
https://www.sau.com.au/forums/topic/343664-bushing-kit-help-needed/
I'm looking for the same part for sedan gt8.
Look here for some info, the ebay listing i've put up is not the correct part though.
http://www.skylinesaustralia.com/forums/Cr...nt-t341075.html
Think this is the correct one
http://cgi.ebay.com/ebaymotors/OEM-INFINIT...sQ5fAccessories
can somebody comfirm?
Edit: sorry just noticed you replied in that thread already ... $600 for labour??
check ur Pm
Edited by nissan rules
Yeah I have 2 cracked bushes which I need to get sorted, I was quoted around $350 for labour, and I still think thats high..so I've been putting it off till next service..
I bought a pair on ebay for $120 delivered, I think I saw recently they even cheaper now.. Genuine nissan part from America.
When it comes to stock parts for the V35, dont bother looking for anything in OZ. It will usually be 3 times the price just so that they can tell you its Genuine Nissan. I've always gone straight to Ebay US and found the best deals there.
Please let me know how much you end up paying of install? i think it requires a 'hydraulic jack' to install.
you could replace the arms yourself, not a massive job. save yourself the coin and learn something in the process. youll need a big jack and some axle stands. youll need to get the whole front end off the ground to do it, dont jack up one side at a time, the swaybar will probably hinder the job.
ebay US is great for parts that are shared between several models.
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
