What exactly is the difference between a R33 GTST and R34 GTT clutch line?
I know the gearbox uses a different slave cylinder due to the push/pull clutch difference (maybe the master is different?). But with an aftermarket braided clutch line that simply is a certain length with a fitting on each end, would there be a difference?
The length of the line would have to be the same so it is simply the fittings that I need to know about. The master cylinder would most likely use the same fitting between the models so really it comes down to the slave cylinder.
Does any one know if the fittings are the same? For reference here is a picture of the braided clutch line on a R33 GTST.
Reason I want to know is that Hel do not make a clutch line for the GTT as they have never seen one, however I am sure the GTST one would have to fit.
Any help would be greatly appreciated.
Cheers
Phil
Edited by PM-R33
Can't imagine them using a different sized thread. I think the R34 GTT is pull-type clutch so the length would probably be different as the slave cylinder goes on the other side of the clutch fork hole.
http://justjap.com/store/images/P/30620-12U0A.jpg
Hmm interesting. When you say the other side of the clutch fork hole, where exactly is that?
I looked on Just Jap's website and this is the GTST one
http://justjap.com/store/images/P/30620-21U23.jpg
So it still bolts onto the same location? Therefore the line would only be marginally different in length?
Edited by PM-R33
As far as I know the pull type slave actually pushes the fork in the other direction (from rear towards the front meaning the fork pulls the clutch to release and doesn't push). So the slave cylinder is mounted at the rear of the hole that the fork protrudes from. It uses different holes to bolt up, possibly already blanked bosses present on non pull type boxes?
Looks to me like the R34 clutch line would have to be longer. Going by the picture on Just Jap it looks like the thread is on on the rear side of that too.
Edited by Mister25t
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
