Where is your Spoiler?
Wiring the car up today so will report back for anyone else that searches this in future.
The light comes on from low oil pressure. Not temp. Did you do a rebuild or just add an ecu etc? What oil are you using and where are you getting the pressure reading from
So like the title says my 97 rs4v has a oil temp sensor but no triple gauges as it was originally factory navigation. My current setup is not using the factory oil pressure sensor as I'm running a link ecu and a real sensor. I did leave the oil temp sensor in. So now as I was working on first start up and bleeding coolant I get the oil light on the dash faintly as the oil temp gets to about 60-70c. Oil pressure is 45psi at idle at the same time. I'm wondering if the temp sender doing this?
Well it runs again! This was a definite case of while I have it apart lol Everything except the body and interior has been restored, refinished, or replaced. @socal_stagea is my IG if you're bored and want to see all the pics.
I already got plug and play Link ecu G4X. Main concern is that the de loom works on s1 motor or not? I already rewired injector and coils loom to suit my bosch injectors and bosch vag coil. I’m not running any Iacv. For cas running the nz wiring kit i bought the neo plug one so it suits the wiring but don’t know it works or it doesn’t matter they work the same on every motor. For wastegate solenoid do i need to wire straight from ecu? What can i do for iat sensor to work or same run from ecu? For Vct solenoid, right now i got s1 vct solenoid on motor so do i need to remove neo connector and add s1 connector to work? Any other thing i missed i need to do to make the motor working on de loom. Any different mechanism on neo vs s1?
