i dont even know my offsets now, will check it when i pull the rims off. but i will calculate it or check it.
also my stagea is AWD
waiting time is about 2 weeks since hes doing 19" rims now and next week will be doing 18" then the following week is 17". woop
problem is i may need to find some spare rims to just sit my car on for a couple of days while they get built.
Also if you domt mind me asking, whos spinning up these new barrels (outer rims) for ya...
I can only think of 2 mobs,
one ive dealt perfectly with, the other is a c*%^ that just doesnt wanna do odd jobs such as widening
paid him 50% pf his quote, he said 4wks then pay balance on pickup
only 14wks later i had to force them to give my wheels & money back cos he hadnt even started yet...
PM me as the above was at least 3.5-4.5yrs ago
and i need to go down this path again with 2 other sets of wheels...
see my sig
Being awd, you will have to keep the rolling diameter the same for front and back or the attessa will trip out! Which makes stagered tyre sizes very tricky, probably best to use the same front and rear! The offsets wont cause any problems, but stags have more room in the front than the back, and 10" will be a very tight fit (will need guard rolling)! *I just picked up 18x9.5 +14 and they dont fit, going to need guard mods (would be the same fit as a 10 +20)!
Im currently using 18x8 +35 with 235/40 all round, and the back fits ok, but the front are swimming in the guards; so a 9 +20 would be a good straight fit (using same tyres)! Id personally use the same front and back! Im about to put the new rims with 255/35 on, but doing some serious guard work to fit them (rolling dia. is about the same as factory)!
my 2cents...
Edited by Zorro
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
