Unique Cars #372 currently has an ADM f/s from WA. Page 207. Reg No GTR091. Is this one on your list?
Yes Terry,
That's been for sale for a long time sadly.
Here - http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-176916&Cr=3
Bob.
They were black cars..........BUT..........
They were not part of the 100 special build.
They were part of the 4-6 evaluation cars that Nissan brought in for testing and compliance testing.
I can't confirm whether there were 4 or 6 of these cars I'm getting both numbers quoted from various sources.
As you can see with my attached pics, the VIN is well before the first batch of 50 cars.
The Japanese ID tag doesn't have the 40Z prefix either that were assigned to the ADM's.
Cheers,
Bob.
Hi Bob - and everyone else, long time reader first time contributor!
Bob, have you had any luck identifying the original 'prototypes' brought in separately to the 100 ADM's?
I understand there is a blue one in Melbourne - just hearsay though.
Hi mate and welcome..........
I know of 3 prototypes....... The interesting thing about them is the VIN's.
They are numbers ending with 11260, 11266 and 11268. So...... were there 9 in total if you fill in the blanks?
I was contacted privately by the gentlemen who owns the blue one in Melbourne (TH1 paintcode). It's not hearsay, it's fact.
Another one, (Gun Metal Grey) is currently for sale on Carsales and the 3rd was the Falken Bathurst 12hr car.
If anyone else knows the whereabouts of any of the others that would be great.
Cheers,
Bob.
Very funny. :D:D:D:D:D
It was actually the wheels that got me thinking it was you........
Let's face it, silver ADM with those wheels. Not many of them around!
Only 24 ever made and I know of at least 1 that has gone to god!
Bob.
  • Like 1
Hi guys,
A good friend of mine bought the green car off Bob Roman in the early noughties. It had the original interior back in it and the only mods were the gear knob, ARC intake air filter box, wheels (not the ones in the AR&T article) and aftermarket suspension. It changed a bit in the years that he had it.
It saw a fair few track days around Sydney and at one stage it was being prepared for Targa Tasmania (but never made it). I remember it kissed the wall at Oran Park and needed to have the whole side resprayed. When we pulled the trim apart we found that it was actually a metallic red car, not black. I'm sure from memory that it had a dark engine bay though. I remember there was something odd about the colour code on the build plate too.
The last time I saw it, it had gold painted R33 GTR wheels on it and his then girlfriend was driving it around.
He eventually sold it about 8-9 years ago to a guy in QLD. I'd love to know where it is now.
  • Like 1
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
