Hi StagMan...........it did not see on the fire wall .....i would think it would be pretty easy  to see....its not hidden away somewhere
silly is it.............i didn't think so.....lol............thats ok...............its still a MONSTER..........thanx again for your help
Cheers Jon
Cheers Jon
28 minutes ago, MyBrosBaby said:
Hi again....ok here are all the numbers of the blue ID plate in order from the top
IE-BNR32
BRN32-000O906
KBNR32RXFSLMZG
KH2   G
RB32DETT 2568
FS5R30APRC41
The "P" in the last line could be an "F".....can't read my own writing.......i'd go to the car but it's not where
i'm sending the email from............thanx again.............Cheers Jon
That decodes to;
BNR32-000906
aug 1989 build
series 1 Japanese Import GTR ( not Australian delivered)
KH2 = gunmetal grey metallic
Very early build GTR with that chassis number.
Update LOL- Duncan you beat me to it.
Edited by RS4StagMan
Hi...you guys are really sick...i luv it.......i recently acquired the car with the passing of my brother..........hence the name.
It is gunmetal gray....Recaro seats....is that standard?........but from what he told me its got a lot of really good bits on it.......what they are i am unsure of......but .........10.9 for the quarter is better than my Fairmont at 11.9 and i know how quick that is...............do you all meet sometime?
Would be great.....your knowledge is incredible......would luv it pick your brains and have a beer at the same time    again thanx for the
input......Cheers Jon
  • Like 1
On 27/01/2017 at 1:26 PM, MyBrosBaby said:
Hi Everyone....Happy New  year to one and all.......looking for some help trying to find out if the recently
acquired 1992 R32 is an import or one of the 100 Aussie delivered cars............Thanks for your input.........Cheers Jon
968 R32 GT-R's were built in the first month of production being August 1989.
Yours is one of these cars....... Courtesy of the GT-R Registry here is the data - http://gtr-registry.com/en-r32-colours.php
Congratulations........ Cheers, Bob.
NOW......the million dollar question..........i gotta have this baby insured..........be real nice to know that the GTR geek world think that should be............i can look on EBAY and assorted sites and get an idea but because of its build date is that relevant to its value.....Jon
20 minutes ago, MyBrosBaby said:
Hi.........as i said your knowledge is incredible...........can i assume that August 1989 was the first release of the car.....and this car was in the first batch of cars made????
Yes correct......... Bob.
Ring Shannons and NRMA Veteran, Vintage and Classic Insurance.
Impossible for us to quote without seeing photos let alone the car.
Bob.
  • Like 1
Hi..i'll do that..............my Fairmont is insured thru Shannon.........just curious to what you guys thought......it is unmarked and when washed and clean looks brand new.....interior is spotless..........has all original mats......stroked and bigger turbo's.....some smart engine management....
its currently at the mechanic getting the roady for the historic plates........cannot wait get get behind the wheel.........again thanx for all the info.............hope we get to chew the fat at some time..............Cheers Jon
Hi Marko..............cute daughter.............thanx for the condolences ............i check with them ....but i might get a good deal as its the second car i'm getting insured thru Shannons......this is weekend research....i picked up the car last Wednesday........Cheers Jon
  • Like 1
  • 4 weeks later...
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
