Hi StagMan...........it did not see on the fire wall .....i would think it would be pretty easy  to see....its not hidden away somewhere
silly is it.............i didn't think so.....lol............thats ok...............its still a MONSTER..........thanx again for your help
Cheers Jon
Cheers Jon
28 minutes ago, MyBrosBaby said:
Hi again....ok here are all the numbers of the blue ID plate in order from the top
IE-BNR32
BRN32-000O906
KBNR32RXFSLMZG
KH2   G
RB32DETT 2568
FS5R30APRC41
The "P" in the last line could be an "F".....can't read my own writing.......i'd go to the car but it's not where
i'm sending the email from............thanx again.............Cheers Jon
That decodes to;
BNR32-000906
aug 1989 build
series 1 Japanese Import GTR ( not Australian delivered)
KH2 = gunmetal grey metallic
Very early build GTR with that chassis number.
Update LOL- Duncan you beat me to it.
Edited by RS4StagMan
Hi...you guys are really sick...i luv it.......i recently acquired the car with the passing of my brother..........hence the name.
It is gunmetal gray....Recaro seats....is that standard?........but from what he told me its got a lot of really good bits on it.......what they are i am unsure of......but .........10.9 for the quarter is better than my Fairmont at 11.9 and i know how quick that is...............do you all meet sometime?
Would be great.....your knowledge is incredible......would luv it pick your brains and have a beer at the same time    again thanx for the
input......Cheers Jon
  • Like 1
On 27/01/2017 at 1:26 PM, MyBrosBaby said:
Hi Everyone....Happy New  year to one and all.......looking for some help trying to find out if the recently
acquired 1992 R32 is an import or one of the 100 Aussie delivered cars............Thanks for your input.........Cheers Jon
968 R32 GT-R's were built in the first month of production being August 1989.
Yours is one of these cars....... Courtesy of the GT-R Registry here is the data - http://gtr-registry.com/en-r32-colours.php
Congratulations........ Cheers, Bob.
NOW......the million dollar question..........i gotta have this baby insured..........be real nice to know that the GTR geek world think that should be............i can look on EBAY and assorted sites and get an idea but because of its build date is that relevant to its value.....Jon
20 minutes ago, MyBrosBaby said:
Hi.........as i said your knowledge is incredible...........can i assume that August 1989 was the first release of the car.....and this car was in the first batch of cars made????
Yes correct......... Bob.
Ring Shannons and NRMA Veteran, Vintage and Classic Insurance.
Impossible for us to quote without seeing photos let alone the car.
Bob.
  • Like 1
Hi..i'll do that..............my Fairmont is insured thru Shannon.........just curious to what you guys thought......it is unmarked and when washed and clean looks brand new.....interior is spotless..........has all original mats......stroked and bigger turbo's.....some smart engine management....
its currently at the mechanic getting the roady for the historic plates........cannot wait get get behind the wheel.........again thanx for all the info.............hope we get to chew the fat at some time..............Cheers Jon
Hi Marko..............cute daughter.............thanx for the condolences ............i check with them ....but i might get a good deal as its the second car i'm getting insured thru Shannons......this is weekend research....i picked up the car last Wednesday........Cheers Jon
  • Like 1
  • 4 weeks later...
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
