No...... That  is not the version fitted to R32's.
They were a (very ugly) generic version with NISSAN printed on the back.
Trust me you don't want them.
They needed to be cut to fit, bloody horrible things.
Photo attached.
  • 3 weeks later...
5 hours ago, RB26DETT 240Z said:
https://www.shannons.com.au/auctions/2017-shannons-sydney-autumn-classic-auction/UC9L6FAOD8X733FX/
So the red ADM r32 gtr went 91k Anyone on these forums picked it up?
Not sure, but I was there -
Cheers...... Bob.
  • Like 4
  • 1 month later...
On 07/06/2017 at 1:54 PM, 21PC said:
Apparently Jun II's running gear has been swapped into a JDM shell and the original Black ADM is being restored
If this is true, it hasn't been done as yet as I did see a recent clip of this and was still an ADM shell
3 hours ago, Aussie_Delivered_R32_GTR said:
Wow..... Just found this......
This is a great share. I enjoyed watching this...i too think that the 32 is undervalued, compare it to the 911 which was ~33% more expensive than the 32 at the time, yet the 911 now fetches up to 300k!!!
Edited by Marko R1
This is one example video of a run done this month. They still used a black shell but you can see there are no ADM bits such as rear taillights which were on the previous shell. Think Andrew from Motive DVD said it also somewhere that I can't remember at the moment.
  • Like 1
  • 3 weeks later...
PLEASE KEEP THIS THREAD CLEAN - LEAST CHAT AS POSSIBLE, ADMIN WILL REMOVE WITHOUT WARNING
This is the thread for the Australian delivered GTR's.
Im not sure of the format we would like or what info we should share. I throw up what I thinks fair, each user can do their own thing.
Colour: Wine red mica
Delivered: August 91
Sold: 10/11/92
Number: 68 of 100 (16907)
KMS: 97800 (books)
Dealership: Alf Barbagallo Nissan WA
Owners: 3
Purchased: Jan 08
Locale: Sunshine Coast QLD.
Currently the car is stock apart from the exhaust, stereo (have original), steering wheel (have original) and side indicators.
Cheers,
Ken
Delivered: May 91
Sold: 1992
Number: 28 of 100 (16075)
KMS: 53, 000
Dealership: Col Crawfords Brookvale. Sydney
Owners: 1
Purchased: 1992
Locale: Sydney.
Bought as a ..."Demo" ...with 7kms on the clock from Col Crawford's Brookvale for $85,000 . This car has original exhaust, radio and front bar in storage. Had a Nismo exhaust Dealer fitted at the time. It has been stolen 3 times and lost several badges to the screwdriver fairies. Has a factory warranty replacement engine fitted (Vspec), although engine running as non vspec7e61cf14bf18ddfdee8044895e3ba3f8.jpg9f58d75cfc027982cfd678263bde2dc0.jpg
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
