No...... That  is not the version fitted to R32's.
They were a (very ugly) generic version with NISSAN printed on the back.
Trust me you don't want them.
They needed to be cut to fit, bloody horrible things.
Photo attached.
  • 3 weeks later...
5 hours ago, RB26DETT 240Z said:
https://www.shannons.com.au/auctions/2017-shannons-sydney-autumn-classic-auction/UC9L6FAOD8X733FX/
So the red ADM r32 gtr went 91k Anyone on these forums picked it up?
Not sure, but I was there -
Cheers...... Bob.
  • Like 4
  • 1 month later...
On 07/06/2017 at 1:54 PM, 21PC said:
Apparently Jun II's running gear has been swapped into a JDM shell and the original Black ADM is being restored
If this is true, it hasn't been done as yet as I did see a recent clip of this and was still an ADM shell
3 hours ago, Aussie_Delivered_R32_GTR said:
Wow..... Just found this......
This is a great share. I enjoyed watching this...i too think that the 32 is undervalued, compare it to the 911 which was ~33% more expensive than the 32 at the time, yet the 911 now fetches up to 300k!!!
Edited by Marko R1
This is one example video of a run done this month. They still used a black shell but you can see there are no ADM bits such as rear taillights which were on the previous shell. Think Andrew from Motive DVD said it also somewhere that I can't remember at the moment.
  • Like 1
  • 3 weeks later...
PLEASE KEEP THIS THREAD CLEAN - LEAST CHAT AS POSSIBLE, ADMIN WILL REMOVE WITHOUT WARNING
This is the thread for the Australian delivered GTR's.
Im not sure of the format we would like or what info we should share. I throw up what I thinks fair, each user can do their own thing.
Colour: Wine red mica
Delivered: August 91
Sold: 10/11/92
Number: 68 of 100 (16907)
KMS: 97800 (books)
Dealership: Alf Barbagallo Nissan WA
Owners: 3
Purchased: Jan 08
Locale: Sunshine Coast QLD.
Currently the car is stock apart from the exhaust, stereo (have original), steering wheel (have original) and side indicators.
Cheers,
Ken
Delivered: May 91
Sold: 1992
Number: 28 of 100 (16075)
KMS: 53, 000
Dealership: Col Crawfords Brookvale. Sydney
Owners: 1
Purchased: 1992
Locale: Sydney.
Bought as a ..."Demo" ...with 7kms on the clock from Col Crawford's Brookvale for $85,000 . This car has original exhaust, radio and front bar in storage. Had a Nismo exhaust Dealer fitted at the time. It has been stolen 3 times and lost several badges to the screwdriver fairies. Has a factory warranty replacement engine fitted (Vspec), although engine running as non vspec7e61cf14bf18ddfdee8044895e3ba3f8.jpg9f58d75cfc027982cfd678263bde2dc0.jpg
  • Like 1
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
