  • 1 month later...
  • 1 month later...
Another ADM coming up for sale at Shannons Melbourne auction in November. Black, nice looking body, interior a little shabby but looks all original otherwise. There's been a lot of turnover recently, rising prices tempting many to cash in..
  • Like 1
This is quite possibly the same seller as previously as he had 5 all up.
Maybe this one in November then early next year.
Bob.
5 of them? Wow, I thought I had an ADM problem...
With that many cars he may have had an opportunity to corner the market like those 3 Melbourne lawyers did with their GTHO's some time ago. lol.
I've almost finished my interior refresh, just the drivers seat to do then move on to paint. After that point I expect she will be too good to use and I will keep her under a blanket suffering from panic attacks whenever the kids get within a 2m radius...
21 hours ago, Marko R1 said:
Bargain - someone should snap it up quick!
It's in great condition from the photos - bit sad that it has only been enjoyed for 39k kms.. That's only 26km a week...
  • 2 months later...
2 hours ago, GTRDaz said:
Looks like someone has snapped this up! Anyone on this forum? And any idea of the final price?
U referring to the silver one advertised for 169k?
Edited by Marko R1
Hey everyone I'm Alex from Brissy
I bought the black adm that went at Shannon's Melbourne Nov Auction. I didn't buy it at auction I bought it off the bloke that flipped it. It was just on carsales num 77. High ks but fairly clean over all. Had two gtrs  in the past one being 108/560 Nismo sold for what seems like a packers or rice crackers now. But look in ng to hold on to the adm. I joined on here as im Looking to find out more info on the adm and go for a cruise if there is anyone local
Cheers Alex
Edited by Jingpong
  • Like 2
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
