22 hours ago, 21PC said:
Yes I saw that. Looks like someone took a butter knife to the VIN stamp.
  • 4 months later...
Evening guys,
For those of you who may be interested, I have started a Facebook group dedicated to the ADM BNR32 GT-R and I would love for you to join us.  You can find us at https://www.facebook.com/groups/2327314067368792.
I have been fortunate enough to purchase my close mate Bob Fulop's ADM and look forward to meeting you around the traps sometime.  I also own a 1994 JDM example and am a longtime fan of the cars.
Cheers,
Mark
  • Like 2
  • 4 weeks later...
If I am correct that is the car that was stolen, had the VIN removed from the firewall and was auctioned by Manheim.
It is currently Qld registered and was previously NSW registration ACR-30D.
I have a Facebook group dedicated to the ADM and you are welcome to join us.  You will find us at www.facebook.com/groups/2327314067368792/
  • 8 months later...
  • 2 months later...
  • 2 months later...
  • 1 month later...
As Steve Gilmore once said "Is there anybody out there?" Been quiet lately!
Still got the BNR32A but unfortunately had a big stone ding in the front bumper which prompted its removal for painting.
More drama when removed. The air duct has cracked at the bolt bracket so I am looking for the first two air ducts before the air cleaner. See drawing attached. Has anybody got them? If so let me know $'s and if this hard up broke pesioner can affordit I will send money.
Thanks and regards
John
Thanks and regards
John
Hi John,
We are still here John - rest assured!
I have reached out to a mate re the parts you are seeking and will let you know if he can assist.
I run a small Facebook group dedicated to the ADM. If anyone is interested you can access it at https://www.facebook.com/groups/2327314067368792/?ref=share
Cheers,
Mark
Hi Mark
Nice to know there is somebody out there. This dinosaur is not on facebook so I'll keep an eye on SAU.
Incidently, the bumper and support bracket are different in the AU models.
I have a heap of spare parts so let everyone know so they can email me what they want.
The car is also up for sale but I don't know how much. Any clues on $range?
Thanks
John
  • 4 weeks later...
On 3/18/2022 at 10:48 PM, John Murray said:
Hi Mark
Thanks
John
Hi John! My name is Rhys, I'm probably somewhat like yourself just the not so fortunate generation version!
If you're looking in selling your baby, I'm interested in talking!
I own an R32 GTS-T M Spec but have been looking for the right upgrade for some time.. I see what you post and see you've taken care of it.. anyway.. if you're looking to sell, get back to me and we can chat! :)
Regards,
Rhys
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
