WTB: (R32) Old Gearstick & Handbrake Boots
G'day all,
I'm after a old set of gearstick and handbrake boots from a R32. MUST be factory items.
I don't care if they have a few holes in them, or fairly worn, as long as each of them are in one piece and come with the wire frames that are down the bottom of them.
And before anyone asks, I don't want to swap them with a new set that I may make, cause I'm still not sure if I'll be making the R32 ones. But I need to get my hands on a set to check them out.
Cheers
J
:P
Hey Jay, my car is currently off the road for a few months while the eng and new turbo are being fitted, so i can send you mine to have a look at, if you decide to make them you will just need to do me a good deal, if not you can just send them back. Let me know if your intereted, only prob is the car is at the painters and i will not have it back for about 2 weeks
Thanks Clint.
The only problem would be that I have to take them all apart (un-stitch them totally) to see if I can make them up....
Once unstitched, I wouldn't be able to sew them back up if I decide not to make them :P
I might try and find a set to by outright first, cause I'd hate myself if I pulled your apart only to find I can't make them :)
Thanks anyway.
J
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
